Sphere targets c10
gregorjev
Full Name: Gregor Novakovic
Company Details: 3D ATA d.o.o.
Company Position Title: Technical director
Country: Slovenia
Sphere targets c10
Post by gregorjev »
I would like to do very precize registration in tunnel scanning (monitoring deformations with C10). For monitoring fixed points I would like to measure sphere targets. I choose this variant, becouse of the limited and dangerous walking in the tunnel.
Has anyone tested the sphere targets:
http://shop.laserscanning-europe.com/La ... a-backpack
c10 with a scanner? If yes what are the experiences? Maybe some other recomendations?
Thanks.
Has thanked: 45 times
Been thanked: 36 times
Re: Sphere targets c10
Post by Matt Young »
I think that you will get very good results using spheres with the C10. I think you will have to fit the sphere targets manually in each scan but the fit should be good.
SCCS RTC
Full Name: Phil Marsh
Skype Name: Phil.H.Marsh
Been thanked: 20 times
Post by SCCS RTC »
We had a client who has been recently monitor a tunnel with a C10 but they used 6" tilt and turn targets with the following 5/8 thread wall anchors.
Using Spheres may have made the site work easier but longer in the office.
M: 07540 201383
E: [email protected]
W: www.sccsurvey.co.uk
Oxbow
Full Name: Eric Bergholz
Company Position Title: CEO
Skype Name: eboxbow
Post by Oxbow »
Dear Gregor,
Flexi Sphere from our shop are compromise between accuracies and long term using.
if accuaries the main issues, then is better to use carbonic spheres. Most of plastic spheres have issues by temperature difference.
Carbonic spheres (gfk material) did have this problem. It have accuaries by approx 0.2 - 0.4 mm in roundness and it quit stabile by temperature changing. You can use also our adapter and prism from the shop.
Shoud be good enough.
http://shop.laserscanning-europe.com/La ... t-Carbonic
for question contact me or [email protected]
..Eric
tbwester
Full Name: Thad Wester
Post by tbwester »
C10 can acquire sphere targets in the field. No need to post process if you do it correctly.
tbwester wrote:C10 can acquire sphere targets in the field. No need to post process if you do it correctly.
Been a while since I used them (with a 2500), but good to know that it is still possible.
pjirwin3
Full Name: Pat Irwin
Company Details: Scientific Analysis Inc
Company Position Title: Field Tech
Skype Name: pjirwin3
Post by pjirwin3 »
Thad
Can you inform me about the process of acquiring sphere targets in the field. We use sphere targets but we acquire during post processing.
mbrown
Full Name: Mike Brown
Company Details: Advanced Simtech
Post by mbrown »
Hi Phil,
Are the 5/8" wall anchor systems something that you are selling on your website as I couldn't see them when I checked?
We currently use a mixture of spheres and tilt and turns, but Cyclone quite often struggles with spherical targets especially when close to the scanner, hence looking to use more tilt and turns wherever possible.
Thanks,
tbwester
Post by tbwester »
pjirwin3 wrote:Thad
Hey Pat,
Here's my entire target workflow.
Image/Scan 360 at needed resolution.
In scanworld, pick all of one type of target (so either all spheres or all HDS, etc...)
In scanner control - Scanner control - acquire targets - acquire spheres from pickpoints.
Thad
pburrows145
Full Name: Paul Burrows
Has thanked: 20 times
Been thanked: 28 times
Post by pburrows145 »
You can also define sphere targets onboard using the 'Manage' option from the main menu, then 'targets'. This means you can define the diameter and then carry out a target scan in the field as you would do with HDS targets.
Contact me or a local support rep if you need assistance setting this up.
FYI, this is also where you can define offsets so you don't have to (re)measure the instrument height/target height each time for a traverse/know backsight routine.
