AutoCAD/Cyclone Limit Box
dlefebvre
13
Full Name: Dylan LeFebvre
Company Details: Allnorth
Company Position Title: Reality Capture Group Lead
Post by dlefebvre »
I'll keep this short...
Cyclone has one of (in my opinion) the best functions of all, the LIMIT BOX! I have just started using CloudWorx and can see the potential for greatness within AutoCAD. The downside, its damn near impossible to do anything inside a large model without a limit box. I have no problem isolating the point cloud to the areas i want to see, but then i'm fighting my model outside of this range. Has anyone developed a third party add on for a similar function to that of Cyclone? If not could someone code it up and sell it to me!
Phill
14
Full Name: Phillip Nixon
Company Details: SKM
Has thanked: 4 times
Been thanked: 38 times
Re: AutoCAD/Cyclone Limit Box
Post by Phill »
Dylan
Just a suggestion, have you tried clip planes in Autocad. Type 3dclip
Phill
dlefebvre
13
Post by dlefebvre »
Phill,
I use '3dclip' in my paperspace viewports when creating the drawing views I want. But when it comes to design in a large model, in modle space, its pretty difficult. I turn off some XREF's as well as some layers to try and minimize the amount of model visible, but nothing comes close to how effective Cyclone's limit box is. Maybe this could be a a function of a later release of Cloudworx!!!??
Phill
14
Post by Phill »
Hey all
This is slightly off the topic that Dylan was talking about earlier but I have made a lisp for making limit boxes a bit more dynamic in cloudworx for autocad. Unfortunalty I am still a bit behind in my versions (running 4.1.2 and Acad2008) so I would like to know if this still works with the changes in the new version. Basically this makes a limit box (CL) that you can edit manually using the handles and then updates the cloud (LU) to match the changes to the box. Only works for cloud, not objects in autocad but it's a start.
Still in Beta testing so give it a try and let me know.
Phill
15
Has thanked: 45 times
Been thanked: 40 times
Post by Matt Young »
I don't know of a limit box function within Cloudworx that will clip the model as well as the point cloud.
There might be an option in later AutoCAD releases?
I find that with careful layer management, the cloud limit box is enough. I only turn on the current layer and model in that.
