Rail Scan + Static Scan
Discuss all Amberg related issues here.
molden
Full Name: Denis Moloney
Company Details: Techeng
Company Position Title: Eng
Country: Eire
Post by molden » Fri Feb 18, 2011 2:57 pm
Has anyone successfully cloud matched a rail scan and abunch of static scans. I'm having real difficulty doing this using two imp. files in cyclone
Has thanked: 6 times
Re: Rail Scan + Static Scan
Post by Matt Young » Fri Feb 18, 2011 3:58 pm
It should be fairly straight forward to run a point to point registration between the two point clouds. You may not get great results, due to the angle that each scan is taken from.
Maybe too late now, but during the scanning process it should be possiblr to switch from kinematic mode to normal scanning and control a few scans along the track.
If you want to make something simple, then take one thing away that still allows you to do the job. Don't add two more things, and say they both make it easier.
christopherbyrne18
Full Name: Christopher Byrne
Company Details: Rio Tinto Iron Ore
Company Position Title: Specialist Surveyor - Mine Engineering
Post by christopherbyrne18 » Sat Feb 19, 2011 12:17 am
Hey Den,
Think it could be due to the way the rail data is scaled to fit and hung on the alignment.
best of luck,
Chris
Return to “Amberg”
