Visual aligment setups - Rotate cloud in Side View is not working
Maciej B3D
Full Name: Maciej
Company Details: B3D Company
Company Position Title: Scanning Engineer
Country: Poland
Post by Maciej B3D »
Hey
I want to visual aligment a link between two setups - from side view. Like on a picture :
https://pasteboard.co/8ERnsbRc7Fpa.png
It def need a "rotate cloud" to align it - but when i press the button with "Rotate cloud" its just rotate both setups so i can just take a look at it arround, but it does not change anything. What's wrong with this option ?
badam
3
Full Name: Adam Berta
Country: Hungary
Has thanked: 52 times
Been thanked: 305 times
Re: Visual aligment setups - Rotate cloud in Side View is not working
Post by badam »
i suggest you to not use it, but if it is a must, then use correct tilt method which is available in side view and you can find it in the bottom left corner.
but this small issues should be aligned automatically by the c2c analyze part, if it makes wrong link then i'd delete the link, then just fix it straight away. without running c2c matching.
Maciej B3D
Full Name: Maciej
Country: Poland
Unlucky I cant correct a tilt, cuz when i press this button i get window with "Setups with a Level condition set by the scanner *_pseries, C-series or RTC360) or by Set Level tool cannot be Tilt corrected" so it seems like its blocked.
badam
3
Country: Hungary
Post by badam »
Maciej B3D wrote: Fri Nov 17, 2023 11:09 am Unlucky I cant correct a tilt, cuz when i press this button i get window with "Setups with a Level condition set by the scanner *_pseries, C-series or RTC360) or by Set Level tool cannot be Tilt corrected" so it seems like its blocked.
if you really untrust this setup i think you can override this by set unleveled (setuptree -> rightclick to the given setup and set unleveled or sth like this). is it from an rtc360 HTA mode?
Maciej B3D
Full Name: Maciej
Country: Poland
What do you mean by HTA mode ?
Maciej B3D
Full Name: Maciej
Country: Poland
badam wrote: Fri Nov 17, 2023 11:36 am
Thanks a lot - untick "use leveled condition helped" - after untick took several seconds and everything aligned as it should be. Dunno if it was setup error. It problem with 2 setups in whole 200 setup bundle.
