2km Pipe Run
- Full Name: Lewis Boxer
- Company Details: Advanced 3D Laser Solutions Ltd
- Been thanked: 4 times
2km Pipe Run
Hi All,
We have been asked to do a survey of a pipe run, which runs roughly 2km, we typically use terrestrial laser scanners like Trimble X7 and the Faro Focus'
But using a normal laser scanner, on a piper un like this will price us out of the job, whcih made me wonder if sometyhing like a geoslam or navvis might work well?
Has anyone had any experience, using a geoslam across such a distance?
Lewis Boxer
Technical Director
e: [email protected]
w: www.lasersurveying.com
Technical Director
- Full Name: Martin Graner
- Has thanked: 160 times
- Been thanked: 175 times
Re: 2km Pipe Run
Depending on the accuarcy you need, if you insert control points to the network with stop and go georeferencing it should work out okayish.
Keep in mind that SLAM works best if there are many natural features in all directions, if there is only the pipe and the floor, the result might be unexpected...
- smacl
- Has thanked: 627 times
- Been thanked: 657 times
Re: 2km Pipe Run
I've seen some excellent client results from NavVis recently. For a pipe run you will really need external control, ideally traversed and possibly levelled but taken with RTK as a bare minimum. Accurate documented positions are very important for pipes that will be covered over in future and levels become very important if the pipes relate to drainage. This is where the external control comes into play where an IMU isn't going to be up to the job by itself.boxel0 wrote: ↑Fri Oct 14, 2022 9:57 am Hi All,
- TommyMaddox
- Company Details: ONSITE3D
- Has thanked: 67 times
- Been thanked: 130 times
Re: 2km Pipe Run
Rent a riegl for the day,
I would recommend shooting control too, 2km run is long enough to where you'd end up with a circle instead of a line for some devices
- MarkJLane
- Full Name: Mark Lane
- Company Details: Faro Technologies
- Company Position Title: ANZ Account Manager
- Has thanked: 25 times
- Been thanked: 43 times
Re: 2km Pipe Run
It's not uncommon for me to scan such distances with the ZEB Horizon.
You can use control points or GPS trajectory to adjust SLAM trajectory to control and georeference.
Relevant examples...
Ski slope
Railway
Car mounted road
Car mounted powerlines
Boat mounted bridge
All the above examples were scanned in <1 hour
- smacl
Re: 2km Pipe Run
Hi Mark,MarkJLane wrote: ↑Mon Oct 17, 2022 4:42 amIt's not uncommon for me to scan such distances with the ZEB Horizon.
Ski slope
Railway
Car mounted road
Boat mounted bridge
Any backpack examples for a linear topographic job? The data in the car mounted road job is too sparse for feature extraction and similarly the rail job is too noisy to clearly see the rail head in either plan or section. I know that Geoslam improved their noise reduction techniques reasonably recently and wonder whether these data sets are from previous iterations? For the trench survey in question, I guess Lewis would need to give us an idea of required absolute and relative accuracy in both plan and elevation i order to figure out appropriate method and equipment.
- Full Name: Ioannis Papas
- Company Position Title: CEO
- Country: EU
- Skype Name: -
- Has thanked: 99 times
- Been thanked: 62 times
Re: 2km Pipe Run
I have spoke with geoslam support and told me that their devices has no the ability to correct the drifting only to georeferenced it.MarkJLane wrote: ↑Mon Oct 17, 2022 4:42 amIt's not uncommon for me to scan such distances with the ZEB Horizon.
Ski slope
Railway
Car mounted road
Boat mounted bridge
- MarkJLane
Re: 2km Pipe Run
With the Horizon, the density of the scan is a function of the speed of the scan and the distance to that surface. Car mounted scans are great for surveying street scapes, including facades, powerlines, etc. But if I need higher density I simply slow down or move closer to that feature.smacl wrote: ↑Mon Oct 17, 2022 11:46 am Hi Mark,
The new filters in GeoSLAM Connect reduce much of the noise typical of mobile scanning. Since the filters are a relatively new feature, many of the older web-hosted sample scans haven't been processed with the new noise filters yet.
Some more relavant example scans. Please note these web-hosted scans stream in over time, sometimes taking a while for greater detail.
Handheld train station
Backpack streetscape
Car mount 3km
- MarkJLane
Re: 2km Pipe Run
This may have been the case in the past, but applying a non-rigid adjustment of the scan to the control file is a common workflow in GeoSLAM Connect
- smacl
Re: 2km Pipe Run
Thanks Mark, those Car mount 3km and Backpack streetscape jobs are considerably better than the previously linked samples. Could I get you to send me a copy of the LAS/LAZ or E57 file associated with them along with trajectory file and any particulars on mountings used, data capture speed etc... I have a client currently looking for a mobile mapping solution which can be used on backpack, vehicle, drone etc... and this is looking far more like a feasible solution now.MarkJLane wrote: ↑Mon Oct 17, 2022 12:34 pmWith the Horizon, the density of the scan is a function of the speed of the scan and the distance to that surface. Car mounted scans are great for surveying street scapes, including facades, powerlines, etc. But if I need higher density I simply slow down or move closer to that feature.
Car mount 3km
