Hello everyone,
I have an issue when i am trying to import data with REGISTER 360, and saving it to a local folder. Even i have full rights on that location, the raw data (*.b2g) isn't saved. I have also tried to run the application as admin and the same result. My Cyclone Register 360 version is 2022.0.0.
Can anyone faced with this problem?
Thanks in advanced!
Best regards,
George
BLK2GO - Cyclone Register 360 - save copy to local folder
- 1
- Full Name: George Vina
- Company Details: Laser scanning and measurements
- Company Position Title: Development manager
- Country: Romania
- Full Name: Adam Berta
- Country: Hungary
- Has thanked: 52 times
- Been thanked: 297 times
Re: BLK2GO - Cyclone Register 360 - save copy to local folder
Where do you set the final directory of the b2g files?georgevina wrote: ↑Thu Apr 21, 2022 12:34 pm Hello everyone,
Thanks in advanced!
Best regards,
George
if you work with cyclone products, keep these in your mind:
- UNC path not supported like (\\nas\share\...)
- don't use any special (utf8) chars in your path, like (áéőúö, etc...)
- 1
- Country: Romania
The location is on local HDD and it is:
D:\temp
D:\temp
- Country: Hungary
what is your log say about that?
%programdata%\Leica Geosystems\logs\Register360_log.txt
This is what i would do:
Why don't you just download with data manager then import the b2g files? That way the import will be faster and it does not uses the licenses unnecessarily.
- 1
- Country: Romania
[2022-Apr-21 15:43:32.289]: ---- Start Cyclone REGISTER 360 2022.0.0 ----
[2022-Apr-21 15:43:32.289]: Build: 2022.0.0.r22715 ----
[2022-Apr-21 15:43:32.890]: Locale name from system: en_US
[2022-Apr-21 15:43:32.920]: OS: Windows 10 (10.0) x86_64 10.0.22000
[2022-Apr-21 15:43:32.920]: Video Card: Intel(R) UHD Graphics, 4.6.0 - Build 30.0.101.1340, 4.6
[2022-Apr-21 15:43:33.371]: Total time to check Connection state for 13 projects: 0.006784
[2022-Apr-21 15:43:33.371]: There are 13 projects
[2022-Apr-21 15:43:33.372]: Loading config file: C:\ProgramData\Leica Geosystems\Cyclone REGISTER 360\Register360Config.ini
[2022-Apr-21 15:43:33.523]: CyClmLicenseMgr:InitializeServer: rHostName localhost
[2022-Apr-21 15:43:33.700]: CyClmLicenseMgr:InitializeServer: InitLicenseConfig() 0.158666 secs
[2022-Apr-21 15:43:34.073]: CyClmLicenseMgr:InitializeServer: InitServerConnection() 0.372314 secs
[2022-Apr-21 15:43:34.294]: CyClmLicenseMgr:InitializeServer: LoadBorrowedLicensesInfo() 0.220597 secs
[2022-Apr-21 15:43:34.294]: CyClmLicenseMgr:InitializeServerLicenses: DetectBetaLicense() 1e-07 secs
[2022-Apr-21 15:43:34.853]: CyClmLicenseMgr:InitializeServerLicenses: LoadRunningModeLicense() 0.558927 secs
[2022-Apr-21 15:43:35.047]: CyClmLicenseMgr:InitializeServerLicenses: RestoreLicenses() 0.193223 secs
[2022-Apr-21 15:43:35.047]: CyClmLicenseMgr:InitializeServer: InitializeServerLicenses() 0.75227 secs
[2022-Apr-21 15:43:35.047]: CyClmLicenseMgr:LoadLicense: sName TLS_CYCL.Register360 sVersion 1.0 isOptional false peekOnly false
[2022-Apr-21 15:43:35.132]: CyClmLicenseMgr:LoadLicenseTrust: mErr -1878982661 error_stream: 'LoadLicense: Feature TLS_CYCL.Register360: Failed to checkout license TLS_CYCL.Register360/TLS_CYCL_Maint.Register360, CLM checkout error E_CLM_NOFEATURE
[2022-Apr-21 15:43:35.132]: CyClmLicenseMgr:LoadLicense: sName TLS_CYCL.Register sVersion 1.0 isOptional false peekOnly false
[2022-Apr-21 15:43:35.147]: LicenseMgr:LogLincensesInfo: IsLicenseLoaded true TryTempCheckout false
[2022-Apr-21 15:43:35.148]:
License TLS_CYCL.Register360 - not loaded yet
FeatName = TLS_CYCL.Register
FeatVer = 2024.0323
EID = 00108-81249-00034-76410-A913D
ProdKey = 00108-81249-00034-76410-A913D:798751
MaintFeatName = TLS_CYCL_Maint.Register
MaintFeatVer = 2024.0323
MaintEID = 00108-81249-00034-76410-A913D
ProductInfo:
EID 00108-81249-00034-76410-A913D
ProdName = 798751
ProdDesc = Cyclone REGISTER Permanent
LicType = Perpetual
ExpireTime = 0/none
MaintExpireTime = 0/none
License TLS_CYCL.Publisher - not loaded yet
License TLS_CYCL.PublisherPro - not loaded yet
License TLS_CYCL.PublisherStandard - not loaded yet
License TLS_JS.Generator - not loaded yet
[2022-Apr-21 15:43:35.215]: Connect: root, 192.168.1.122|192.168.42.2
[2022-Apr-21 15:43:35.266]: Connect: root, 192.168.1.122|192.168.42.2
[2022-Apr-21 15:43:35.277]: Total time to check Connection state for 13 projects: 0.0090576
[2022-Apr-21 15:43:35.279]: Temp folder = C:/Users/George/AppData/Local/Temp/Register360/
[2022-Apr-21 15:43:46.791]: Clearing Scan Importer
[2022-Apr-21 15:43:46.791]: Find Project with Name TestImport or Guid or Source/ClientId .
[2022-Apr-21 15:43:46.791]: Searching cache for project TestImport...
[2022-Apr-21 15:43:46.791]: Project found.
[2022-Apr-21 15:43:46.791]: GetProjectSetupsFolder(): storage systems folder is not found: "".
[2022-Apr-21 15:43:46.791]: GetProjectSetupsFolder(): isLocal=false, mStorageSystemSetupsFolder="", mProjectCacheSetupsFolder="", return="".
[2022-Apr-21 15:43:46.791]: Adding folder "" to required-space amp. Required size = 0.0003 GB.
[2022-Apr-21 15:43:46.791]: Warning: folder has no drive specified, so defaulting to "C:". Folder = "".
[2022-Apr-21 15:43:46.791]: ----- Diskspace Check-------
[2022-Apr-21 15:43:46.791]: Available space on "C:\": 208.4 GB. Required Project storage, estimated 0.0 GB.
[2022-Apr-21 15:43:46.791]: GetProjectInfo(): Failed to get project info for project TestImport.
[2022-Apr-21 15:43:46.792]: GetProjectInfo(): Failed to get project info for project TestImport.
[2022-Apr-21 15:43:46.792]: Adding project with client id DP - TestImport.
[2022-Apr-21 15:43:46.799]: Added project with client id DP - TestImport
[2022-Apr-21 15:43:46.799]: File C:\ProgramData\Leica Geosystems\Cyclone REGISTER 360\ProjectData\7dbf625f-7b53-42c2-9b87-ba6a5ea14888\project_version_1650545026000.db does not exist (The system cannot find the file specified).
[2022-Apr-21 15:43:46.830]: GetVersionInfoFromRec(): bundle count for version 'TestImport_1' is 0.
[2022-Apr-21 15:43:46.830]: WriteArchiveInfo for TestImport
[2022-Apr-21 15:43:46.831]: Created project 'TestImport' at: C:\ProgramData\Leica Geosystems\Cyclone REGISTER 360\ProjectData\7dbf625f-7b53-42c2-9b87-ba6a5ea14888
[2022-Apr-21 15:43:46.834]: License Info for project TestImport set successfully.
[2022-Apr-21 15:43:46.834]: Setting state for project TestImport.
[2022-Apr-21 15:43:46.837]: GetVersionInfoFromRec(): bundle count for version 'TestImport_1' is 0.
[2022-Apr-21 15:43:46.837]: WriteArchiveInfo for TestImport
[2022-Apr-21 15:43:46.839]: Active version for project TestImport set to TestImport_1.
[2022-Apr-21 15:43:46.840]: GetVersionInfoFromRec(): bundle count for version 'TestImport_1' is 0.
[2022-Apr-21 15:43:46.840]: WriteArchiveInfo for TestImport
[2022-Apr-21 15:43:46.850]: InitProjectPaths(): rProjectCacheFolder="C:/Users/George/AppData/Roaming/Leica Geosystems/Register360\7dbf625f-7b53-42c2-9b87-ba6a5ea14888", rProjectTempFolder="C:/Users/George/AppData/Local/Temp/Register360/7dbf625f-7b53-42c2-9b87-ba6a5ea14888", rProjectCacheSetupsFolder="C:/Users/George/AppData/Roaming/Leica Geosystems/Register360\7dbf625f-7b53-42c2-9b87-ba6a5ea14888\SetupsFolder", rStorageSystemSetupsFolder="C:/ProgramData/Leica Geosystems/Cyclone REGISTER 360/ProjectData/7dbf625f-7b53-42c2-9b87-ba6a5ea14888\SetupsFolder".
[2022-Apr-21 15:43:46.864]: Changing bundle count to 0.
[2022-Apr-21 15:43:47.438]: DetermineWorkflowStage: Requested Stage = "". numDeliverables = 0, numSetups = 0, numAssets = 0, workflowStage = 1.
[2022-Apr-21 15:43:47.440]: Clearing Scan Importer
[2022-Apr-21 15:43:47.441]: GetProjectSetupsFolder(): isLocal=true, mStorageSystemSetupsFolder="C:/ProgramData/Leica Geosystems/Cyclone REGISTER 360/ProjectData/7dbf625f-7b53-42c2-9b87-ba6a5ea14888\SetupsFolder", mProjectCacheSetupsFolder="C:/Users/George/AppData/Roaming/Leica Geosystems/Register360\7dbf625f-7b53-42c2-9b87-ba6a5ea14888\SetupsFolder", return="C:/ProgramData/Leica Geosystems/Cyclone REGISTER 360/ProjectData/7dbf625f-7b53-42c2-9b87-ba6a5ea14888\SetupsFolder".
[2022-Apr-21 15:43:47.441]: Adding folder "C:/ProgramData/Leica Geosystems/Cyclone REGISTER 360/ProjectData/7dbf625f-7b53-42c2-9b87-ba6a5ea14888\SetupsFolder" to required-space amp. Required size = 0.0001 GB.
[2022-Apr-21 15:43:47.441]: ----- Diskspace Check-------
[2022-Apr-21 15:43:47.441]: Available space on "C:\": 208.4 GB. Required Project storage, estimated 0.0 GB.
[2022-Apr-21 15:43:50.504]: GetDiscoveredDevices:: List time: 2029.93 ms, number of devices 1
[2022-Apr-21 15:43:58.300]: GetDiscoveredDevices:: List time: 2025.45 ms, number of devices 1
[2022-Apr-21 15:44:08.983]: ScanReader - Open:
[2022-Apr-21 15:44:08.983]: '.tukan'
[2022-Apr-21 15:44:13.494]: Reading Blk2Go scanner took 4.53097 seconds.
[2022-Apr-21 15:44:46.609]: GetProjectSetupsFolder(): isLocal=true, mStorageSystemSetupsFolder="C:/ProgramData/Leica Geosystems/Cyclone REGISTER 360/ProjectData/7dbf625f-7b53-42c2-9b87-ba6a5ea14888\SetupsFolder", mProjectCacheSetupsFolder="C:/Users/George/AppData/Roaming/Leica Geosystems/Register360\7dbf625f-7b53-42c2-9b87-ba6a5ea14888\SetupsFolder", return="C:/ProgramData/Leica Geosystems/Cyclone REGISTER 360/ProjectData/7dbf625f-7b53-42c2-9b87-ba6a5ea14888\SetupsFolder".
[2022-Apr-21 15:44:46.609]: Adding folder "C:/ProgramData/Leica Geosystems/Cyclone REGISTER 360/ProjectData/7dbf625f-7b53-42c2-9b87-ba6a5ea14888\SetupsFolder" to required-space amp. Required size = 0 GB.
[2022-Apr-21 15:44:46.610]: Adding folder "C:/Users/George/AppData/Local/Temp/Register360/7dbf625f-7b53-42c2-9b87-ba6a5ea14888" to required-space amp. Required size = 1.30385e-07 GB.
[2022-Apr-21 15:44:46.610]: ----- Diskspace Check-------
[2022-Apr-21 15:44:46.610]: Available space on "C:\": 208.4 GB. Required Project storage, estimated 0.0 GB.
[2022-Apr-21 15:44:46.610]: Not using normals for target matching.
[2022-Apr-21 15:44:46.636]: ScanImporter::PerformImport: 1 datasources
[2022-Apr-21 15:44:46.636]: Datasource has 1 setups, OverallNumPoints 10
[2022-Apr-21 15:44:46.636]: GetProjectSetupsFolder(): isLocal=true, mStorageSystemSetupsFolder="C:/ProgramData/Leica Geosystems/Cyclone REGISTER 360/ProjectData/7dbf625f-7b53-42c2-9b87-ba6a5ea14888\SetupsFolder", mProjectCacheSetupsFolder="C:/Users/George/AppData/Roaming/Leica Geosystems/Register360\7dbf625f-7b53-42c2-9b87-ba6a5ea14888\SetupsFolder", return="C:/ProgramData/Leica Geosystems/Cyclone REGISTER 360/ProjectData/7dbf625f-7b53-42c2-9b87-ba6a5ea14888\SetupsFolder".
[2022-Apr-21 15:44:46.636]: Warning: User has selected "Balanced" threading-mode for import, but some of the readers do not support multi-threading. Multi-threading is being turned off.
[2022-Apr-21 15:44:46.636]: Import is configured to use 1 thread(s) for import. ThreadMode=Balanced, gbFastFlag=false, CanBeThreaded=false, HasMxData=false, ScanImporter.mNumThreads=6, CubemapSize=2048.
[2022-Apr-21 15:44:46.636]: Performing import in ScanImporting. Multi-threaded = false.
[2022-Apr-21 15:44:46.637]: Perform Import: multi-threading is turned off.
[2022-Apr-21 15:44:46.637]: DataSourceInfo::PerformImport: 19 setups
[2022-Apr-21 15:44:46.637]: Setup id 1: number of scans: 1
[2022-Apr-21 15:44:46.637]: PerformImport: SKIPPING setup 1 not READY_FOR_IMPORT (status 2).
[2022-Apr-21 15:44:46.637]: Setup id 2: number of scans: 1
[2022-Apr-21 15:44:46.637]: PerformImport: SKIPPING setup 2 not READY_FOR_IMPORT (status 2).
[2022-Apr-21 15:44:46.637]: Setup id 3: number of scans: 1
[2022-Apr-21 15:44:46.637]: PerformImport: SKIPPING setup 3 not READY_FOR_IMPORT (status 2).
[2022-Apr-21 15:44:46.637]: Setup id 4: number of scans: 1
[2022-Apr-21 15:44:46.637]: PerformImport: SKIPPING setup 4 not READY_FOR_IMPORT (status 2).
[2022-Apr-21 15:44:46.637]: Setup id 5: number of scans: 1
[2022-Apr-21 15:44:46.637]: PerformImport: SKIPPING setup 5 not READY_FOR_IMPORT (status 2).
[2022-Apr-21 15:44:46.637]: Setup id 6: number of scans: 1
[2022-Apr-21 15:44:46.637]: PerformImport: SKIPPING setup 6 not READY_FOR_IMPORT (status 2).
[2022-Apr-21 15:44:46.637]: Setup id 7: number of scans: 1
[2022-Apr-21 15:44:46.637]: PerformImport: SKIPPING setup 7 not READY_FOR_IMPORT (status 2).
[2022-Apr-21 15:44:46.637]: Setup id 8: number of scans: 1
[2022-Apr-21 15:44:46.637]: PerformImport: SKIPPING setup 8 not READY_FOR_IMPORT (status 2).
[2022-Apr-21 15:44:46.637]: Setup id 9: number of scans: 1
[2022-Apr-21 15:44:46.637]: PerformImport: SKIPPING setup 9 not READY_FOR_IMPORT (status 2).
[2022-Apr-21 15:44:46.637]: Setup id 10: number of scans: 1
[2022-Apr-21 15:44:46.637]: PerformImport: SKIPPING setup 10 not READY_FOR_IMPORT (status 2).
[2022-Apr-21 15:44:46.637]: Setup id 11: number of scans: 1
[2022-Apr-21 15:44:46.637]: PerformImport: SKIPPING setup 11 not READY_FOR_IMPORT (status 2).
[2022-Apr-21 15:44:46.637]: Setup id 12: number of scans: 1
[2022-Apr-21 15:44:46.637]: PerformImport: SKIPPING setup 12 not READY_FOR_IMPORT (status 2).
[2022-Apr-21 15:44:46.637]: Setup id 13: number of scans: 1
[2022-Apr-21 15:44:46.637]: PerformImport: SKIPPING setup 13 not READY_FOR_IMPORT (status 2).
[2022-Apr-21 15:44:46.637]: Setup id 14: number of scans: 1
[2022-Apr-21 15:44:46.637]: PerformImport: SKIPPING setup 14 not READY_FOR_IMPORT (status 2).
[2022-Apr-21 15:44:46.637]: Setup id 15: number of scans: 1
[2022-Apr-21 15:44:46.637]: PerformImport: SKIPPING setup 15 not READY_FOR_IMPORT (status 2).
[2022-Apr-21 15:44:46.637]: Setup id 16: number of scans: 1
[2022-Apr-21 15:44:46.637]: PerformImport: SKIPPING setup 16 not READY_FOR_IMPORT (status 2).
[2022-Apr-21 15:44:46.637]: Setup id 17: number of scans: 1
[2022-Apr-21 15:44:46.637]: PerformImport: SKIPPING setup 17 not READY_FOR_IMPORT (status 2).
[2022-Apr-21 15:44:46.637]: Setup id 18: number of scans: 1
[2022-Apr-21 15:44:46.637]: PerformImport: SKIPPING setup 18 not READY_FOR_IMPORT (status 2).
[2022-Apr-21 15:44:46.637]: Setup id 19: number of scans: 1
[2022-Apr-21 15:44:46.637]: Scan dimensions 1 x 10 = 10 points
[2022-Apr-21 15:44:46.637]: PerformImport:: setupsToProcess 1
[2022-Apr-21 15:44:46.637]: Setup Name BLK2GO-3631128-48 has server ID
[2022-Apr-21 15:44:46.647]: GetVersionInfoFromRec(): bundle count for version 'TestImport_1' is 0.
[2022-Apr-21 15:44:46.650]: Changing bundle count to 0.
[2022-Apr-21 15:44:46.700]: --> PerformImport mWayPointIds 1
[2022-Apr-21 15:44:46.700]: Importing in single-threaded manner.
[2022-Apr-21 15:44:46.701]: Processing the first setup(s).
[2022-Apr-21 15:44:46.701]: Importing unstructured setup 1...
[2022-Apr-21 15:44:46.701]: Begin importing setup 1 of 1
[2022-Apr-21 15:44:46.701]: Reading points via HandleMainScanData()...
[2022-Apr-21 15:44:46.701]: ReadScanData(22612): Waiting to read scan data for scan 4294967315.
[2022-Apr-21 15:44:46.701]: ReadScanData(22612): Reading scan data for scan 4294967315.
[2022-Apr-21 15:44:46.701]: TukanReader: WayPointsAndColors is enabled.
[2022-Apr-21 15:44:46.701]: TukanReader: Loop Closure is disabled.
[2022-Apr-21 15:44:46.701]: TukanReader: Use existing slam is enabled.
[2022-Apr-21 15:44:46.701]: TukanReader: Import Images is enabled.
[2022-Apr-21 15:44:46.701]: TukanReader: Voxel filter level is Full.
[2022-Apr-21 15:44:46.702]: TukanReader: Fetching BLK2FLY dataset to "C:/Users/George/AppData/Local/Temp/Register360/7dbf625f-7b53-42c2-9b87-ba6a5ea14888\d8cafb7f-9fd1-4103-af9b-1d47567f3d84.dat".
[2022-Apr-21 15:45:32.532]: TukanReader: Finished fetching BLK2FLY dataset. 45.8299 s
[2022-Apr-21 15:45:35.263]: TukanReader: Calculating BLK2GO pose trajectory with version 3.2.2. Loop closure disabled. Skip Slam disabled. Use Existing enabled
[2022-Apr-21 15:45:35.264]: TukanReader: using on-device SLAM
[2022-Apr-21 15:45:36.043]: TukanReader: Finished calculating BLK2GO trajectory.. 0.779629 s, cancelled = false
[2022-Apr-21 15:45:47.017]: TukanReader: Skipped 19 of 337 images.
[2022-Apr-21 15:45:47.047]: TukanReader: Read 318 images in 11.0036 seconds
[2022-Apr-21 15:45:47.047]: TukanReader: Processing poses for scan-id '4294967315'.
[2022-Apr-21 15:45:47.047]: TukanReader: Finished processing poses for scan-id '4294967315'.
[2022-Apr-21 15:45:47.048]: Creating memory-mapped file for points...
[2022-Apr-21 15:45:47.049]: Creating memory-mapped file for intensities...
[2022-Apr-21 15:45:47.050]: Creating memory-mapped file for colors...
[2022-Apr-21 15:45:47.051]: Creating memory-mapped file for time...
[2022-Apr-21 15:45:47.055]: TukanReader: Reading 38245033 points for scan-id 4294967315 in chunks of 500000.
[2022-Apr-21 15:47:32.659]: TukanReader: For part scan: Read 10000000 / 38245033 points.
[2022-Apr-21 15:47:33.049]: TukanReader: For part scan: Read 15536903 / 38245033 points.
[2022-Apr-21 15:47:33.120]: TukanReader:: fetchPointCloud returned 1
[2022-Apr-21 15:47:33.120]: Tukan Reader: filter Full, read 15536903/38245033 points, 40.6246 percent in 106.068 seconds
[2022-Apr-21 15:47:33.121]: ReadScanData(22612): Finished reading scan data for scan 4294967315.
[2022-Apr-21 15:47:33.122]: ImporterUnstructured, rows, cols 15536903 1
[2022-Apr-21 15:47:33.162]: ProjectImport: Calculating normals...
[2022-Apr-21 15:47:40.006]: Time to calculate normals : 6.84354 seconds.
[2022-Apr-21 15:47:40.006]: Sampling trajectory for setup BLK2GO-3631128-48.
[2022-Apr-21 15:47:41.044]: Saving U16 timestamps, span = [9276677531, 21216872896]
[2022-Apr-21 15:47:41.045]: TukanReader: Processing poses for scan-id '4294967315'.
[2022-Apr-21 15:47:41.045]: TukanReader: Finished processing poses for scan-id '4294967315'.
[2022-Apr-21 15:47:41.045]: __ TukanTrajecttory SampleTrajectory begin ApplyTimeFilter( maxPoints=18446744073709551615, frequency=0.2 (secs) )
[2022-Apr-21 15:47:41.045]: __ TukanTrajecttory SampleTrajectory after ApplyTimeFilter, elapsed time=0.0006257, points=466
[2022-Apr-21 15:47:41.045]: __ TukanTrajecttory SampleTrajectory begin ApplyShapeFilter( maxPoints=18446744073709551615, tolerance=-1, spacing=0 )
[2022-Apr-21 15:47:41.045]: __ TukanTrajecttory SampleTrajectory after ApplyShapeFilter, elapsed time=2e-07, points=466
[2022-Apr-21 15:47:41.045]: __ TukanTrajecttory SampleTrajectory begin ApplyDistributionFilter( maxPoints=18446744073709551615, tolerance=0
[2022-Apr-21 15:47:41.045]: __ TukanTrajecttory SampleTrajectory after ApplyDistributionFilter, time=1e-07, points=466
[2022-Apr-21 15:47:41.095]: Creating resource file: C:\ProgramData\Leica Geosystems\Cyclone REGISTER 360\ProjectData\7dbf625f-7b53-42c2-9b87-ba6a5ea14888\SetupsFolder\2cc50c88-961b-41c5-bcc0-4781c3e111c6.trj.
[2022-Apr-21 15:47:41.105]: Adding scan 4294967315 to point-cloud for setup 'BLK2GO-3631128-48'...
FeatVer = 2024.0323
ProductInfo:
ProdName = 798751
LicType = Perpetual
ExpireTime = 0/none
- Country: Hungary
this is not the whole log try to attach it as txt instead. You probably cutted down the point of the log. Because it didn't reach the copy part.
- 1
- Country: Romania
I have tried to attached the whole log file saved like txt file, but the forum platform warns me that is invalid extension.
I don't know if there are any filters, is my first post here.
- 1
- Country: Romania
I have converted in rtf file, and seems it works. This is the whole log.
- Country: Hungary
I don't see any mention in the log file about saving the b2g files nor your output directory.
As i mentioned earlier:
If you need backup files i'd stick with the download (blk data manager) and then import method.
