Unwrapping hyperboloid pointcloud shape with colour
To chat about anything else.
Ioannis
5
Full Name: Ioannis Papas
Company Position Title: CEO
Country: EU
Skype Name: -
Has thanked: 67 times
Been thanked: 30 times
Post by Ioannis »
Hello, I have a pointcloud chimney in a shape like a hyperboloid how its possible to unwrapping it with colour?
Pointcab has only unwrapping of cylinder shapes not hyperboloid or cones.
The shape is similar to the attached.
Waiting for your help.
Leandre Robitaille
2
Full Name: Leandre Robitaille
Company Details: Cima+
Has thanked: 47 times
Been thanked: 128 times
Re: Unwrapping cone shape
Post by Leandre Robitaille »
you can try best fitting 2 cones with cloudcompare, split the chimney at an exact elevation in 2 pointcloud and use the exact radius for both projections you generate. You can then export those projection afterwards and overlap them in autocad to get a full picture.
Btw You need to identify the dimensions/radius with meter units in autocad and use those values in Cloudcompare
Someone might have a better idea for your curved shape. You will get some distortion in the unwrapping if its not a perfect fit.
landmeterbeuckx
10
Full Name: Lieven Beuckx
Has thanked: 102 times
Been thanked: 324 times
Post by landmeterbeuckx »
Luposcan can unwrap cones. It is in this software but i never used that function.
LSBbvba
Tel : +32477753126
www.lsbbvba.be
max72
9
Full Name: Massimo De Marchi
Skype Name: massimo_de_marchi
Has thanked: 13 times
Been thanked: 31 times
Post by max72 »
Mind the shape is not a cone. It's probably an hyperboloid.
https://en.wikipedia.org/wiki/Cooling_tower
https://en.wikipedia.org/wiki/Hyperboloid
Mike Annear
13
Full Name: Mike Annear
Company Details: The Yard Brisbane
Company Position Title: Manager - 3D Design and Scanning
Has thanked: 112 times
Been thanked: 179 times
Post by Mike Annear »
I vaguely remember using the "Surface of Revolution" function to "unroll" the interior surface of Crushing mills back when I was doing that sort of work.
https://www.cloudcompare.org/doc/wiki/i ... s_(plugin)
Perhaps that would work ? You could draw the profile from a cross section of your scan.
Mike.
Mike Annear
www.mikeannear.com
QLD, Australia.
Ioannis
5
Country: EU
Skype Name: -
Re: Unwrapping hyperboloid pointcloud shape with colour
Post by Ioannis »
Any other solution in order to have a nice ortho like pointcab?
smacl
11
Full Name: Shane MacLaughlin
Has thanked: 397 times
Been thanked: 412 times
Post by smacl »
Ioannis wrote: Sat Jan 22, 2022 5:18 pm Any other solution in order to have a nice ortho like pointcab?
SCC can unwrap relative to one or more arbitrary shapes (section templates) extruded along an arbitrary polyline (alignment). The section templates can also be cut from the point cloud at specified intervals to get an accurate unwrap. There's a sample video below from 2018 and the functionality has been significantly enhanced over the last couple of years.
youtu.be/3NCsG-ltXKk
To use this on a hyperboloid, you'd first have figure out how you wanted the surface developed / unwrapped. Easiest would be a circular alignment and hyperbolic sections as the reference surface for unwrapping.
Ioannis
5
Country: EU
Skype Name: -
Post by Ioannis »
Ι would never imagine that it would be so difficult!
stevenramsey
14
Full Name: Steven Ramsey
Company Details: 4DMax
Skype Name: steven.ramsey
Has thanked: 28 times
Been thanked: 54 times
Post by stevenramsey »
Ioannis wrote: Sat Jan 22, 2022 12:19 am Hello, I have a pointcloud chimney in a shape like a hyperboloid how its possible to unwrapping it with colour?
As you can see there are a few ways to do it also you can search the forum as there is a routine called unfurl which I have used.
But the bigger question is what type of projection do you clients request. ie which dimensions do you wish to be correct.
Steven Ramsey
Home [email protected]
Work [email protected]
Mobile +44 7766 310 915
Ioannis
5
Country: EU
Skype Name: -
Post by Ioannis »
stevenramsey wrote: Mon Jan 24, 2022 9:36 am
Client want a perfect unwrap model with colour in order to view the damage of Chimney and calculate quantities for repair.
Programs that i had so far is Cylone full, pointcab and cloud compare.
Return to “General Chat”
