RTC360 Still a Good Buy?
- Full Name: Andrew
- Company Details: Stainless Specialists Inc
Our company is budgeting for a RTC360 this year as it is the next logical step for us. We have demo'd one already and we already own the necessary software, so it was easy to get up and running. We would be moving from a BLK360 (big jump, I know). What I'm trying to figure out, is if the RTC360 is still worth 80k as it stands. It was released in 2018 and has had a substantial amount of firmware upgrades made to it to make it "better".
Is the next big scanner release right around the corner or do you think we'd be good pulling the pin on something like this in 2022?
- Leandre Robitaille
- Company Details: Cima+
- Has thanked: 61 times
- Been thanked: 246 times
Re: RTC360 Still a Good Buy?
Having used most scanners in the market...if I would have to start over and buy my first big scanner...I would go for the riegl vz400i.
- Mike Annear
- Full Name: Mike Annear
- Has thanked: 122 times
- Been thanked: 196 times
It depends a lot on what type of work you will be doing with the scanner.
I notice that you guys are a stainless steel fabrication company ?
Do what we did, organise a side by side test of whatever scanners you think that you might buy as per your budget.
Scan an object that you would typically scan for your work, test each scanner from the same scan position under the same conditions etc.
Dont let the dealers try to baffle you with their sales pitch, just go by the results, time in the field, ease of use of software, ongoing costs etc.
Every scanner has its pros and cons, everyone on this forum will have their own favourite brand and model, a lot of it is also based on workflow.
Having said that, if you are keeping your BLK360, and adding a RTC360, it would make sense to stick with Leica.
Mike.
Mike.
- landmeterbeuckx
- Full Name: Lieven Beuckx
- Country: Belgium
- Has thanked: 183 times
- Been thanked: 548 times
Good choice, a VZ400i. I did a school yesterday.? 242 scans.Leandre Robitaille wrote: ↑Fri Jan 21, 2022 12:34 am Having used most scanners in the market...if I would have to start over and buy my first big scanner...I would go for the riegl vz400i.
85 outdoor scans in color (45 seconds a scan)
others inside (30 seconds a scan)
Scanner on a dolley. Started at 9h00, ended at 13h30 without break.
All registered and exported on pc in 1,5 h.
6 hours in total. Can't beat this.
- smacl
- Has thanked: 627 times
- Been thanked: 657 times
Fully costed side by side comparison for the specific workflows you're using makes a lot of sense, though as per Leiven's post, you really need to look at field to finish times (e.g. scan + registration + processing) for a typical job rather than just field time. Very easy to lose time saved on site, and much more besides, in a slow office workflow. I'd also talk to the dealer about ongoing maintenance costs, including time taken to calibrate and cost and availability of a replacement unit for any down time. Basically, try to find out all the hidden costs and potential time wasted as part of your trial.Mike Annear wrote: ↑Fri Jan 21, 2022 2:36 am It depends a lot on what type of work you will be doing with the scanner.
Mike.
- Full Name: Ioannis Papas
- Company Position Title: CEO
- Country: EU
- Skype Name: -
- Has thanked: 99 times
- Been thanked: 62 times
The hidden costs are the maintenance support and software updates that a big disadvantage of Leica!
- Mike Annear
Hi Guys...
I thought we were talking scanners around the $80k mark ?
So that would rule out the VZ400i ?
Above $80k range we could also include the Z&F range, Leica P series, Trimble, Topcon scanners etc.
BTW, we chose the Faro S70 in our comparison. ~ $80k ....
Mike.
Mike.
- landmeterbeuckx
- Country: Belgium
My deal was around 90k€ a few years agoMike Annear wrote: ↑Fri Jan 21, 2022 10:17 am Hi Guys...
Mike.
- Mike Annear
Sorry Lieven,
I meant about $80K Aussie, ($60K USD ) I think your scanner is about $140K (Aussie) on the same scale.
I have used Riegl scanners a lot for mining work,(Training mining surveyors) I was the first person to test a VZ-1000 in the field in Australia
http://www.riegl.com/media-events/newsl ... ian-field/
All my photos .. Riegl VZ series are great scanners.
Mike.
Mike.
- steves01x
- Full Name: Steve Smith
- Company Details: Scanning
- Country: Scotland
- Has thanked: 31 times
- Been thanked: 57 times
If your work flow is already Leica, i would upgrade to Cyclone Core if you go with another Leica scanner.
The RTC is brilliant for measured building surveys, fits in a lot of places and its quickest scan is just over 30 seconds. The integrated camera is not too bad for an additional 60 seconds but it wont match the Riegl external DSLR. But i am pretty sure the RTC will be about the half price before any additional maintenance/warranty etc.
What are you guys going to be scanning? As if its larger sites, more accuracy required and longer range etc all of which the BLK isnt any use at, the P40 maybe a better solution than the RTC360 and they aint a huge amount more money!
