Comparison Geoslam Zeb Horizon, Navvis VLX, Kaarta Stencil 2 and Gexcel Heron
- Country: Italy
- Has thanked: 15 times
- Been thanked: 53 times
Re: Comparison Geoslam Zeb Horizon, Navvis VLX, Kaarta Stencil 2 and Gexcel Heron
I have a Faro and a Horizon, so I understand your idea..
I'll write my opinions, related to the two scanners I have, the tools I use and my main activities (mainly building survey).
While if I would have to select a single tool to do all my jobs a TLS would be the way to go, both instruments have strength and weaknesses.
I heavily rely on pointcab, and the workflow affects the opinion on the different tools.
When doing facades, mainly of old buildings, my Faro is way better. The details obtained from Pointcab are very crisp, nothing to compare with Horizon. If I need more details I add photogrammetry.
Another aspect is the quality of the intensity data. For instance manholes are more evident with Faro (using Pointcab and intensity).
On the other hand the Horizon is much faster, and brings excellent results in almost all the other situations I encounter. In many situations, both inside and outside of a building the data from Horizon is perfect, and while it's noisier it's perfect for the task, and a Faro wouldn't add much.
Another plus is Horizon is very portable, and you can access difficult to reach areas, as long as you advance slowly and are careful.
I use Hub, and while it works really well sometimes registering the scans skew them (I guess it's a bug..). Now there is Connect that offers pointcloud filtering and some other things.
Cross checking raw and filtered data, and using Pointcab I cannot see an advantage in all this filtering, besides an aesthetic effect. To be fair, I prefer the raw data, and decide what to take. I dropped filtering completely.
With my Faro I use Scantra as a registration tool, and the workflow is very fast and reliable. Nonetheless I now use Horizon as the primary tool, and the Faro for special situations.
Considering the fast setup, and the great range, I use the Horizon as a topographic tool combined with my GPS.
If I need to exploit more informations from the pointcloud I use Rhino with Veesus plugin.
Another thing to consider in my opinion:
Geoslam support is excellent (even if I'm not sure they understood the cloud combine skew bug).
Scantra support is excellent.
Pointcab support is excellent.
Veesus support is excellent, but I'm a reseller so take it with a grain of salt.
- GeomDaniloMammarella
- Full Name: Danilo Mammarella
- Company Details: Technical Office
- Company Position Title: CEO
- Country: Italia
- Has thanked: 23 times
- Been thanked: 5 times
Hi Massimo,max72 wrote: ↑Fri Jan 07, 2022 7:50 pm I have a Faro and a Horizon, so I understand your idea..
Thank You very much for your post! The day before yesterday I've seen here some of your posts and a minute after I was on your site..
I promise to me to disturb you with a phone call when I've got ten minutes. And now I've to say thank you for your precious advices!
I hope to call you soon ( pheraps on saturday )
Danilo
- Country: Italia
Wait a moment.. what you mean when you say "NavVis processing costs per SquareFeet" ?GeomDaniloMammarella wrote: ↑Fri Jan 07, 2022 7:33 pmWhy alignment tools aren't great? Have you got some alignment problem in your experience?jsteinert wrote: ↑Fri Jan 07, 2022 2:35 pm We have been using BLIK2G0 and VLX for over a year. Both have advantages and limitations.
From our experience the 2Go works very well with RTC/BLK360 and LGS provides 270 pano waypoints. VLX imagery is excellent and filtering from pointcloud processing is great.
However the 2Go image quality is limited and pointcloud is not very dense. NavVis processing costs per SF, quite slow processing, and alignment tools aren't great.
Even after considering cost of instrument, time to process, overall quality, and cost of processing... I still havent seen a solution from any MLS that provides an RCP with panos included from any mobile solution.
Do you mean that you pay the NavVis software and than you pay a quote per SF to process data??
Please tell me that I misunderstood
I love to be free from any subscription etc if it's possible.. I'm not very old but I begin with my eyes on a theodolite, and a piece of paper and a pen in the other hand.
A software is only a beautiful and useful calculator from my point of view, you should not pay to calc. You should pay to buy the calculator. That's only my personal opinion..
I hope that I misunderstood about payment per SF
Danilo
- Country: Italy
Anytime!GeomDaniloMammarella wrote: ↑Fri Jan 07, 2022 9:59 pm
Hi Massimo,
Danilo
- joshhillgeoslam
- Full Name: Josh Hill
- Company Details: GeoSLAM
- Company Position Title: Product Marketing Specialist
- Has thanked: 4 times
- Been thanked: 7 times
Hi Danilo
Please allow me to contribute some information from a GeoSLAM point of view.
At GeoSLAM, we've made some really big leaps forward in 2021, including enhancements to our SLAM algorithm, launching a new software platform (GeoSLAM Connect) which comes as standard with ay ZEB product, new processing and analysis tools and filters, and a workflow library to automate results such as change detection and automatic floorplan detection. You just select which workflow you want to run and the software will do the rest. We are set to launch the next version of Connect (2.1) very soon and included in this release will be a new noise filter and outlier removal tool. These filters will be applied automatically to any dataset during the processing stage, which will result in very clean and clear point clouds.
Now that this feature is ready to be released, we will also be applying this to all of the sample datasets on our website in order for any existing or potential customers to see the full capabilities of our systems and software.
We also published an accuracy report last year evaluating the accuracy results of the ZEB Horizon compared with other similar LiDAR systems. Here is the link if you would like to read it: https://geoslam.com/wp-content/uploads/ ... Report.pdf
If you would like more information about GeoSLAM Connect and our SLAM algorithm (GeoSLAM Beam), please click on this link: https://geoslam.com/solutions/connect/
For reference, the cost of the ZEB Horizon is around £39,000 and this includes hardware, a data processing licence for GeoSLAM Connect and a year's worth of our after sales package GeoSLAM Care (this includes hardware warranty, remote software support and software updates). The Connect licence is perpetual and there is no extra charge for data storage or processing so the return of investment is usually very fast.
If you have any further questions, please don't hesitate to message me or email any member of the GeoSLAM Team.
Kind regards
Josh
Kind regards
Josh
Last edited by joshhillgeoslam on Tue Jan 11, 2022 8:57 am, edited 1 time in total.
- Full Name: joshua steinert
- Company Details: pb2 architecture + engineering
- Company Position Title: Graphics Manager
- Has thanked: 20 times
- Been thanked: 12 times
for navvis alignment you cannot correct tilt, and any rotational correction is limited to .5 degree increments.GeomDaniloMammarella wrote: ↑Fri Jan 07, 2022 7:33 pmWhy alignment tools aren't great? Have you got some alignment problem in your experience?jsteinert wrote: ↑Fri Jan 07, 2022 2:35 pm We have been using BLIK2G0 and VLX for over a year. Both have advantages and limitations.
NavVis processing is indeed a pay to process/host utility. It used to be based on SF, but now is based on pano count.GeomDaniloMammarella wrote: ↑Fri Jan 07, 2022 10:21 pmWait a moment.. what you mean when you say "NavVis processing costs per SquareFeet" ?GeomDaniloMammarella wrote: ↑Fri Jan 07, 2022 7:33 pmWhy alignment tools aren't great? Have you got some alignment problem in your experience?jsteinert wrote: ↑Fri Jan 07, 2022 2:35 pm We have been using BLIK2G0 and VLX for over a year. Both have advantages and limitations.
Danilo
- landmeterbeuckx
- Full Name: Lieven Beuckx
- Country: Belgium
- Has thanked: 183 times
- Been thanked: 548 times
So you don't pay a yearly fee for processing but have a per sq/m cost?jsteinert wrote: ↑Mon Jan 10, 2022 4:57 pmNavVis processing is indeed a pay to process/host utility. It used to be based on SF, but now is based on pano count.GeomDaniloMammarella wrote: ↑Fri Jan 07, 2022 10:21 pmWait a moment.. what you mean when you say "NavVis processing costs per SquareFeet" ?GeomDaniloMammarella wrote: ↑Fri Jan 07, 2022 7:33 pm
Danilo
That's like these credits for a 2x2x2 m window at geoslam earlier. Impossible to calculate a decent price to quote
- stevenramsey
- Full Name: Steven Ramsey
- Company Details: 4DMax
- Skype Name: steven.ramsey
- Has thanked: 30 times
- Been thanked: 72 times
Nope. I was very disappointed when I was told this (for images not sure about panos) online processing always a interesting discussion.Is it possible to export panoramic images with pose informations?
- Full Name: Adam Berta
- Country: Hungary
- Has thanked: 51 times
- Been thanked: 297 times
And always the most expensive... But you have the opportunity to support startuppers... It is not viable for long term i think. Same goes for not onpremise services in other areas.stevenramsey wrote: ↑Mon Jan 10, 2022 6:00 pmNope. I was very disappointed when I was told this (for images not sure about panos) online processing always a interesting discussion.Is it possible to export panoramic images with pose informations?
