Hi everyone. I am lacking confidence into using some of the settings on the sphere remover app. What would be a good rule of thumb setting I should use for
-''position deviation''
-''scan point distance''
-''scan point drift''
To me they all sound the same, what is the difference between all 3 settings and what would be a good value to use to have an accurate sphere and clean out some bad players?
I first run the ATS quality manager ''find missing references'' at 1.5mm ''maximum point distance error'' what ever that is, then I use taglabs with the 81 point number to distance filter my 145mm spheres, and 23m to distance filter my 200mm spheres.
For the record I use a lot of spheres in my projects, I used 32 spheres on my last project with 2 scanners, my scans see a lot of spheres (usually 10-12 each). I also make sure they all have at least 3 spheres link using ATS quality manager after cleaning out spheres. I just like to swarm a corridor I am scanning with a lot of spheres and focus on moving scans instead of moving spheres all the time. So my scans detect spheres that are far/less accurate,I want to keep only the good ones.
Thanks!
Taglabs sphere remover settings, what do you use?
- Leandre Robitaille
- Company Details: Cima+
- Has thanked: 61 times
- Been thanked: 246 times
Re: Taglabs sphere remover settings, what do you use?
Hi
For whom it may interest, I have started using the default values for the app for the 3 settings I was questioning about and have gotten noticeable better registration. See picture bellow; However, does anyone know what those settings actually mean and how they differ?
and in ATS quality manager
Any input is appreciated,
thanks!
thanks!
- Full Name: Scan ku kaï
- Company Details: Scankukai
- Company Position Title: CEO
- Country: France
- Has thanked: 58 times
- Been thanked: 207 times
We developed this plugin.
We have listed the values that Faro displays in the sphere detection properties, but do not have a detailed explanation of each value.
Personally, I use the following values:
- number of points: 36,
- position deviation: 2mm.
So I only keep the spheres with more than 36 points, and whose position deviation is less than 2mm.
