Scan Locations not visible in Recap
- 2
- Full Name: Jim Gerrard
- Company Details: Gerrards Design and Drafting Inc
- Been thanked: 3 times
Hello LSF Community
I'm new to this, so please be gentle.
We have been using the BLK 360 along with Register 360 (BLK) edition for 9 months now. Our work flow is to register the scans in Register 360 (BLK) then export as an RCP file, that we would open up in Recap Pro and Revit. Initially, when opening the RCP file in recap we could see the mirror balls (scan locations) and click on the location to view the Panoramic images and scan information. See image below of a RCP file created in January 2021. It seems that since the June 14/21 (I believe it was then) Register 360 (BLK) update, we are not able to view the mirror ball locations in Recap any more. See image below of the same RCP file exported in August 2021. I have checked various settings in Recap, and in Register 360 (BLK), (such as visibility of mirror balls, which is on) but cannot find how to resolve this problem. Perhaps there was a change in some Register 360 (BLK) settings, but I cannot find a way to turn the scan location back on in Recap, or while I export in Register 360 (BLK).
Further, if I look at the various support folders where the cloud data is saved, I can see in the January Scans .diff, .llt, .rcc , and .thumbnail files in addition to the .rcs and .rcp files. Since the June update, all of these files have been removed, and only the .rcs files remain.
Viewing scan locations and registration of scans work effectively while in Register 360 (BLK), so I am thinking the problem is related to the exporting of the RCP file.
I have been querying the internet to see if there is a solution, however, I cannot seem to find one. Has anyone else been experiencing the same problem? Does anyone have any suggestions on how to fix?
I appreciate your replies,
Jim
Jim
- Full Name: Bart Man
- Company Details: Laser Scanning
- Company Position Title: Passionate about making amazing PCs
- Has thanked: 38 times
- Been thanked: 68 times
Re: Scan Locations not visible in Recap
Can't confirm... We run Publisher Pro, with full Regiser360 and have had no issues. recently exported a project of just over 800 scans all registered into a single bundle with no issues.JimmyG wrote: ↑Tue Aug 10, 2021 9:19 pm Hello LSF Community
We have been using the BLK 360 along with Register 360 (BLK) edition for 9 months now. Our work flow is to register the scans in Register 360 (BLK) then export as an RCP file, that we would open up in Recap Pro and Revit. Initially, when opening the RCP file in recap we could see the mirror balls (scan locations) and click on the location to view the Panoramic images and scan information. See image below of a RCP file created in January 2021.Before Scan.jpg
It seems that since the June 14/21 (I believe it was then) Register 360 (BLK) update, we are not able to view the mirror ball locations in Recap any more. See image below of the same RCP file exported in August 2021.After Scan.jpg I have checked various settings in Recap, and in Register 360 (BLK), (such as visibility of mirror balls, which is on) but cannot find how to resolve this problem. Perhaps there was a change in some Register 360 (BLK) settings, but I cannot find a way to turn the scan location back on in Recap, or while I export in Register 360 (BLK).
Jim
Are you checking the box on Finalize to export as separate stations?
Now all that being said... It wouldn't surprise me if the free ride of separate stations is over with BLK Edition, and you are required to have a Publisher license if you actually want the separate stations.
We do provide Registration as a service with the exports.
www.3dls.xyz
- 2
Thanks for the options. I have checked and can confirm the following:
I have clicked on "accept" then "accept" in the finalize tab. no other options exist for me under this tab Then, under the Publish options, I have tried both options of RCP (Cloud) [saves RCP file as one file with not separation of each setup] and RCP (Cloud) [which saves as one cloud file with each set up registered separately]. unfortunately both options do not work. I too am concerned that they keep removing functionality from the Register 360 (BLK) version and limiting it to the full Register 360 only version. The export to LGS option has been removed long time ago (from what I have heard)
In Leica's defense. It isn't so much remove functionality The BLK360 was not really a Leica Product in the idealistic sensei, just as much an Autodesk release as a Leica release. Then when Autodesk dropped support, despite being the joint launch, Leica offered the BLK edition at a substantially reduced price point, giving people a year to transition from the loss of support from Autodesk.JimmyG wrote: ↑Wed Aug 11, 2021 12:54 am Thanks for the options. I have checked and can confirm the following:
I have clicked on "accept" then "accept" in the finalize tab. no other options exist for me under this tab finalize.jpg
Then, under the Publish options, I have tried both options of RCP (Cloud) [saves RCP file as one file with not separation of each setup] and RCP (Cloud) [which saves as one cloud file with each set up registered separately]. unfortunately both options do not work. Publish.jpg
With Full Cyclone Core and Register360 we have always required a version of Publisher license to do any kind of ReCAP or LGS/TruView exports. So that BLK Edition, even gave it as a favor was a sore point with us, that pay for full licenses, as we run multiple different scanners on projects.
Thus Basically Leica gave a nice cushiony transfer period for BLK owners to discover the power of Register360 over ReCAP. Now that little free gift is going away, and will need pay up Even the price of BLK Edition keeps increasing. Won't be long till the only option is Register360.
- Full Name: Martin Graner
- Has thanked: 160 times
- Been thanked: 175 times
Sorry I don't have a fix only a comment to your summary:JimmyG wrote: ↑Tue Aug 10, 2021 9:19 pm Hello LSF Community
Jim
You are completely correct here: The Autodesk Format can safe point clouds structured (with mirrorballs) and unstructured (no mirrorballs / unified).
When the mentioned files, like .diff, .llt, .rcc etc are missing, then the file was written unstructured.
The .rcs files are the raw viewing point clouds, everything else is for the mirrorballs.
I would be very astouned if the structured export was removed from your version, perhaps you can try to install an older version of the software and retry?
I think the best way to proceed is to contact your Leica reseller.
Did Autodesk really drop the support or did the contract with Leica just expire and therefore the Autodesk products were discontinued?RJGEOMATICS wrote: ↑Wed Aug 11, 2021 1:15 am
Would love to hear some insights here from both sides
- 2
Hello All,
Thank you for your insights. I did contact my reseller and they tried to replicate the problem on their end. They ran a few tests, and were able to get everything to work normally, as it should. That is to say, they did get the Mirror Balls to show up in Reacap while using Register 360 BLK.
I think that we (my reseller and I) found out that this is not a Register 360 BLK vs Full Register 360 issues, but rather one needs a 'Publisher Pro' add-on to the Register 360 BLK to Export to LGS, 360 Panoramic images and also to export to a RCP format that would include the Mirror Balls along with 360 panoramic images for Recap viewing. I've tried to search the Leica site to find out more information about Publisher Pro, and while I have not spent a huge amount of time searching, I have not easily found something that explains what and how this add-on is used.
I guess I am confused as to why Leica does not provide all the required software in one simple and easy to purchase service. Why do we need to purchase a Cyclone Subscription Base, and a Register 360 BLK, and a Publisher Pro license? To me, it seems like to much a-la-carte picking with no real full and complete package options.
- landmeterbeuckx
- Full Name: Lieven Beuckx
- Country: Belgium
- Has thanked: 183 times
- Been thanked: 548 times
My buddy RJGEOMATICS told this in this thread.JimmyG wrote: ↑Tue Aug 17, 2021 7:21 pm Hello All,
This segmentation of Leica software is not only on their scanners but also on their total stations. All routines will have to be bought seperately.
- smacl
- Has thanked: 627 times
- Been thanked: 657 times
Very much the same experience here with one of my customers. I'd assumed LGS was a native format for all Leica products and was dismayed to find that it is actually a paid for extra in Reg-360.JimmyG wrote: ↑Tue Aug 17, 2021 7:21 pmI guess I am confused as to why Leica does not provide all the required software in one simple and easy to purchase service. Why do we need to purchase a Cyclone Subscription Base, and a Register 360 BLK, and a Publisher Pro license? To me, it seems like to much a-la-carte picking with no real full and complete package options.
