pipe modelling software
- Full Name: Malte Holm
- Company Details: TLS
- Country: Norway
Hi All
I am from time to time modelling pipes and such.
It has been done in cyclone modeller, but it starts to seem a little bit oldfashioned and it isnt so easy, to deliver models to our customers, foing all have to be converted from COE.
I have seen, that some are starting to use AutoCAD Cevil, but i was wondering if there is any other softwares, that people are using.
Which one is the market leader?
- Leandre Robitaille
- Company Details: Cima+
- Has thanked: 61 times
- Been thanked: 246 times
Re: pipe modelling software
For quick extractions use edgewise
For ISO drawings/modelling use faro as built plugin for plant 3d
- Full Name: Lewis Boxer
- Company Details: Advanced 3D Laser Solutions Ltd
- Been thanked: 4 times
Autodesk Plant 3D has built in functionality to help its not automated but it allows you to focus on one pipe at a time
Lewis Boxer
Technical Director
e: [email protected]
w: www.lasersurveying.com
Technical Director
- Country: Norway
- Full Name: Jakub Bies
- Company Details: Scanning
- Company Position Title: Technican
- Country: Poland
I have worked with EdgeWise trial and I can admit it is useful for quick pipe extraction. This is a big advantage.
Also, an advantage is so that there is a minimum difference between Point Cloud and EdgeWise extracted pipe. Accuracy depends mainly on scan resolution/quality and coverage area (especially coverage area is an important factor for extraction).
There is a significant time saving by using EdgeWise.
Disadvantages I have faced were working with insulated pipes. Because surface of the material for insulation is not,,regular”, extraction of this kind of pipes take time.
Also, I faced a problem with creating tees connection. Where two tees connections are close to each other, then it is possible to create only one.
Very important point is compatibility with other software. In EdgeWise you can define standard dimension for pipes/ valves etc. Software is very functional when you can bring intelligence information to other software.
Hope, that I help a little bit with pipe modelling software. I would like to ask if you know of any software similar to EdgeWise? Maybe you have guys some experience with other software?
- Full Name: Duy Nguyen
- Company Details: Baezeni VietNam
- Company Position Title: Baezeni VietNam
- Country: Vietnam
- Skype Name: duy_bz
- Has thanked: 8 times
- Been thanked: 8 times
Use faro asbuilt autocad with plant3D, if you need model by revit you can convert from autocad to Revit
- Country: Poland
Thank you for your post. But what if I do not use AutoCad plant3D as a basic software for modelling?
- JShubin
- I have made 30-40 posts
- Full Name: JShubin
- Company Details: Kohera3D
- Company Position Title: Laser Scanning Specialist
- Has thanked: 17 times
- Been thanked: 13 times
Take a look at Kohera3D Piping. The export is a dxf file with pipe centerlines (polylines) that can be traced over in most programs that support dxf file import. Plant3D has a "line to pipe" command one can use to pretty quickly convert the dxf to pipe models.
Kohera3D - Laser Scanning Solutions
Website https://www.kohera3d.com
Contact [email protected]
Point Cloud to Mesh - Point Cloud to Piping - Point Cloud Segmentation
- Full Name: Paul Malatzky
- Company Details: Point Share Plus
- Company Position Title: CEO
- Has thanked: 7 times
- Been thanked: 11 times
Not sure if you are still looking, but can highly recommend Clearedge 3D Edgewise, I think they still have a Plant 3D Plug-in too. Pipe extraction is pretty much fully automatic with a few interactions at key points in the workflow.
They have a very nice knowledge base here...
https://www.clearedge3d.com/support/edgewise/
- Full Name: Mattias Svensen
- Company Details: FARO
- Company Position Title: Senior Account Manager FARO Scandinavia
- Country: Sweden
- Has thanked: 3 times
- Been thanked: 6 times
FARO offers both direct-plugin to Autocad/Autocad Plant3D and AsBuilt for Revit / RevitMEP. These are all very powerful and works semi-automatic with an catalogue-driven database using an algorithm to figure out cylindral shaped items. Its using both pointcloud and pictures- with the ability to use each scan-position individually the process of finding pipes and so on is very easy to use.
You can also import different file-format from other vendors than FARO.
Give it a try for a free trial- we offer a go-through if you want me to arrange that.
https://knowledge.faro.com/Software/As-Built
