With coordinate metrology, the relative accuracy to the range of measurement is more practical than the nominal one. E.g., a measurement accuracy of 1 nm is too low for 10 nm pattern of semiconductor circuit. In contrast, a measurement accuracy of 1 mm is too high for 1 km long bridge.
The range of relative measurement accuracy for industrial applications:
1. The lower bound: 1/100, i.e. 1 cm for 1 m
2. Usual requirement: 1/1,000 ~ 1/100,000
2. The upper bound: 1/1,000,000, i.e. 1 mm for 1 km.
There are a variety of measurement methods and tools available for industrial applications.
For moon observation, a telescope.
For cell investigation, a microscope.
Joon
1mm accuracy
- Dave Andrews
- Full Name: Dave Andrews
- Company Details: R.E. Warner Associates Inc.
- Company Position Title: 3d Scanning Coordinator
- Been thanked: 22 times
Re: 1mm accuracy
Haha yeah it’s a touch pricey. Our tracker rate is 4 times the survey rate.landmeterbeuckx wrote: ↑Sat Mar 07, 2020 5:07 amwow, you got to have some decent jobs for this gear to earn it back. I suppose the rates aren't as conventional surveying?Dave Andrews wrote: ↑Fri Mar 06, 2020 5:51 pmWe have a little over $140k in 1 tracker and everything to do what we need. Now, we also do high precision alignment so the tooling needs a huge expense.landmeterbeuckx wrote: ↑Fri Mar 06, 2020 3:05 pm
What price range are these trackers actually? I knwo Leica and Faro have them but have never used or seen one irl.
"The harder you work, the harder it is to surrender."
Woody Hayes
Woody Hayes
- stevenramsey
- Full Name: Steven Ramsey
- Company Details: 4DMax
- Skype Name: steven.ramsey
- Has thanked: 30 times
- Been thanked: 72 times
Re: 1mm accuracy
Usual question has anyone bothered asking the client what they are using the data for and helping them understand what level of Accuracy/precision they really actually need
- 15
- Full Name: James Rye
- Has thanked: 28 times
- Been thanked: 69 times
Re: 1mm accuracy
Yes, we've asked the client - they are looking at a subsidence issue. The trouble is that when a client reads something like the article below, why wouldn't they want the best possible accuracy?
https://www.spar3d.com/news/lidar/faro- ... -accuracy/
We get over-specced tenders all the time! Clients asking for 2mm point spacing on a building facade and then when you deliver, they cannot work with the point cloud and so we have to reduce it.
- jcoco3
- Full Name: Jonathan Coco
- Company Details: Consultant
- Has thanked: 70 times
- Been thanked: 157 times
Re: 1mm accuracy
That's a shame I wish you luck in educating your client...if you can.
There is a saying that I have heard that is a good representation of this ignorance problem.
"Measure it with a micrometer, mark it with caulk, cut it with a chainsaw."
How is the contractor going to ensure they hit that mark even if you can? This is why I also suggested supplying tracker services during construction.
Edit: Sounds like the project is still over-specified, but at least you might get a chance to use a tracker, and possibly charge 4x what you would normally due to their ignorance. I think that it would be better to educate them and get the specified accuracy reduced, but in the event that fails you will still be giving them excellent data.
- Full Name: Scott Page
- Has thanked: 205 times
- Been thanked: 78 times
