Combine 2 bundles
BelgiumLaser
Full Name: Geert
Company Details: Geert
Combine 2 bundles
Post by BelgiumLaser »
I have two bundles in the same site map. I have applied some survey points on each bundle and the errors are a minimum.
I don't know how I can put these bunldes into one bundle? The first bundle are scans from inside a building, the other from outside.
I though that when I import the coördinates of some targets with the total station, it would work to combine them but it isn't.
I work with Register360. Some ideas?
stevenramsey
Full Name: Steven Ramsey
Company Details: 4DMax
Skype Name: steven.ramsey
Has thanked: 17 times
Been thanked: 14 times
Re: Combine 2 bundles
Post by stevenramsey »
as you have applied survey control to both bundles they are in ecense one bundle now. If you want to see all the stations act as one bundle you could select any two scans and add and lock a link (do not align just lock) this will make it one bundle
Steven Ramsey
Home [email protected]
Work [email protected]
Mobile +44 7766 310 915
BelgiumLaser
Full Name: Geert
HEllo, I exported it to one LGS file and it makes one cloud of it. So, in Register360 I saw it as two seperate bundles, but in fact they were indeed in the same coördinate system! It works, thanks.
