Leica BLK2Go
Discuss all BLK2GO related products here
pburrows145
Full Name: Paul Burrows
Has thanked: 13 times
Been thanked: 17 times
Re: Leica BLK2Go
Post by pburrows145 »
I've been testing the BLK2GO extensively and I am really quite happy.
Demo data will be available once the unit is 100% ready for shipping (all the images shown here from the screen we had running at Intergeo were non-final, non-filtered and non-optimised from data we collected last week).
As we move towards a pre-xmas release, the unit will get better and better.
What I am most amazed at so far is the data clarity and the image mapping. Also, the speed of processing is impressive...
I am sure you will enjoy using the BLK2GO as much as I have over the past few weeks.
dhirota
Full Name: Dennis Hirota
Has thanked: 3 times
Been thanked: 4 times
Re: Leica BLK2Go
Post by dhirota »
For those that are concerned about a USB-C port on the BLK2GO, here is the photo that I took at the InterGeo2019 Hexagon booth.
Since it is located in the battery compartment, I should have asked how it was going to work with the battery installed and taken a USB-C cable for them to show how it was going to work. With the USB-C cable plugged in, it is probably producing the power, not needing the battery.
Dennis Hirota, PhD, PE, LPLS
tbwester
Full Name: Thad Wester
Re: Leica BLK2Go
Post by tbwester »
Whats the sensor used?
dhirota
Re: Leica BLK2Go
Post by dhirota »
The Hexagon booth at Intergeo 2019 was giving out cards with this link for more information
https://www.blk2go.com/
"DUAL AXIS LiDAR DOME
The smallest dual axis LiDAR available with best-in-class accuracy, enclosed in a fully protected and encapsulated dome that scans up to 700,000 points per second. Both axes constantly spin while scanning."
pburrows145
Re: Leica BLK2Go
tbwester wrote:
Mon Sep 23, 2019 7:57 pm
Proprietary Leica Geosystems sensors (not sure about the IMU - but impressed with the levelness of the scans I have completed with the device).
Not long to wait now! :geek:
justinm.hays
Full Name: Justin Hays
Company Details: ADF Engineering
Re: Leica BLK2Go
Post by justinm.hays »
dhirota wrote:
Mon Sep 23, 2019 12:51 am
Would this only power it for transfers? Could we plug in a USB battery pack to extend scan times if needed without swapping batteries?
pburrows145
Re: Leica BLK2Go
45 minutes of scanning is a LOT... (off 1 of the 3 supplied batteries)
The port is only used for data download - not power.
I am now able to download via USB-C directly into Cyclone REGISTER 360/BLK Edition...
PCavill
Full Name: Piers Cavill
Company Details: PC Jersey Laser Scanning Ltd
Country: Jersey
Skype Name: pierscavill
Re: Leica BLK2Go
Post by PCavill »
Hi Paul (or any other Leica peeps)
Any chance of giving an indication of accuracy @ range and density at a standard/slow walking pace before the official stats are released? Cost is kinda out there already.
Really want to consider this as a companion or replacement to my very fine BLK360. I realise it's being argued that it's not a direct replacement but it is clearly targeting the same market that the BLK360 is/was and if it makes my time on site faster (as well as projects previously impossible due to not having a static base) with the same output, then I have to consider it as viable.
Also really glad multiple batteries come in the pack and the USB connection is a nice addition too.
Looking forward to the official specs whenever they are dropped into the website if you aren't able to give an indicator in advance, kind regards
Piers
Ioannis
Full Name: Ioannis Papas
Company Position Title: CEO
Country: EU
Skype Name: -
Has thanked: 6 times
Been thanked: 8 times
Re: Leica BLK2Go
Post by Ioannis »
Can we also know the price of it plus software and ccp packages? If it is more than 35000 euro does not worth I think 🤔 ...
the new Trimble scanner has better specs and its not slam .. it is light weight and at price range of 30000-35000 euro ..
If anyone have worked with slam scanners he can understand me..accuracies from 3-5 cm and more..
pburrows145
Re: Leica BLK2Go
Scan density is based on your walk-speed, proximity to a surface etc, there is no defined "point spacing".
Accuracy specs are still not 100% final as they are making final tweaks in the run up to release. I am 100% happy with the data as it stands. It should be perfectly suited to your needs
Register 360 (BLK Edition) is 900EUR/yr on subs.
Return to “Leica BLK2GO”
