Faro focus 150s pins on top
JkX7
Full Name: Jiri Krejci
Company Details: DiGiTry Art Technologies
Company Position Title: SEO - Photogrammetry and laser scanning
Country: Czech Republic
Post by JkX7 » Wed Mar 13, 2019 2:37 pm
Hi, i need some expert advice with two connectors on top of the scanner head (see attached image). Can by used for mounting camera to take panoramas?
TommyMaddox
Full Name: Tommy R Maddox III
Company Position Title: Sales Engineer- AEC Tech Specialist
Re: Faro focus 150s pins on top
Post by TommyMaddox » Wed Mar 13, 2019 2:51 pm
FYI the port across from the red one should be black and it looks like you have a missing or damaged component somehow. I've posted a few times on this topic and you can see some of the resources available to you below, which were copied over from a comment I made on another thread:
viewtopic.php?f=49&t=13500
There are some good resources about the accessory bay ports in this thread.
From one of my comments:
https://knowledge.faro.com/Hardware/Las ... r_Scanners
Above is a link to download the CAD model for the connector interfaces.
https://knowledge.faro.com/Hardware/Las ... he_Focus_S
Above is a link to the automation manual for the FARO FOCUS S scanner. Note that the black accessory bay port is a USB port. The Red accessory bay port is a CAN-Bus port. The pin-out diagrams for both ports are in this manual, along with a sample wiring diagram. It appears both ports have a 14.4-19V pin and ground for powering accessories.
There is lots of fun stuff in the Automation Interface Manual, but the material relevant to the accessory bay ports starts on page 49.
https://knowledge.faro.com/Hardware/Las ... er_Scanner
Above is information about the FOCUS S LS SDK and API. The one you need to control the scanner is the SDK-DEV or the SCENE Stand-alone API. You will need to contact your FARO Rep or Customer Support and sign an NDA and such. If you are not a programmer, or don't have access to a programming team, this probably will not be of much use to you.
JkX7
Post by JkX7 » Wed Mar 13, 2019 3:36 pm
thank you for quick replie. We have cover caps on them, but you are right, one part is maybe missing. Can you make those links live?
Return to “FARO”
