Separating a Point Cloud into Sections
CaptureRI
Full Name: Ashley Forbes Reville
Company Details: CaptureRI
Post by CaptureRI »
I am trying to separate a large file; 20GB, into sections so that I can render the point cloud without my computer bogging down. Does anyone know how I can go about doing this? Clipping Plane? Clean/Separate? Screenshots attached of the File I'm trying to break down into sections;
Capture RI
401.662.3853
www.captureRI.com
gilles_3DR
Full Name: Gilles Monnier
Company Details: Technodigit
Re: Separating a Point Cloud into Sections
Post by gilles_3DR »
Hi ashley,
There are several ways to split your point cloud!
  • the tool clean and separate will allow you to split thebpoint cloud according to a fence which you can define a depth. This tool is manual but gives a lot of options.
  • the clipping plane / clipping box tool allows you to visualize only the points within a slice / a box. Remember that the clipping plane/box do not split the points into different groups. You can use the clipping plane to split though: using the command cloud / separate with clipping.
  • another way to slice the points is to use "objects". The most natural object is a plane: define a plane and then select the plane and the point cloud, the command cloud / separate with object allows you to either group all the points within a distance to the plane into one set or to split the opints from each side of the plane. Note: this also works with cylinders, spheres, meshes, polylines...
My favorite one would be the clipping plane / box as you can see the results before separating.
Nice sailing ship by the way ;)
Did you also scan the inside?
CaptureRI
Post by CaptureRI »
Hi Gilles,
Thanks for the quick reply!
I'll try these options out!
All the best,
Capture RI
401.662.3853
www.captureRI.com
Return to “Cyclone 3DR”
