VZ1000 and Trimble R8
Discuss all Riegl related products here.
goatroxley
Full Name: Mark
Company Details: Consmins
Post by goatroxley »
Hello
Thanks for the adding me to the group guys. I have a small problem with my VZ1000 and Trimble R8
I'm currently setting up a new base station and as such trying to program a spare R8 to work with the VZ1000 on the new frequency. However I can not get the scanner to receive the local grid coordinates. The scanner is currently integrated with another R8 on the old base frequency and working correctly. The NMEA strings on this R8 are GGA, GSA, GST, ZDA, PJK, PJT. dO Do these needed to be added in a certain order?
landmeterbeuckx
Full Name: Lieven Beuckx
Has thanked: 37 times
Been thanked: 77 times
Re: VZ1000 and Trimble R8
Post by landmeterbeuckx »
contact Riegl at [email protected] .
Enough specialists to help you out there and almost instant replies!
LSBbvba
Tel : +32477753126
www.lsbbvba.be
Darul Ikhsan
Full Name: Darul Ikhsan Kholiq
Company Details: PT. Almega Geosystems
Company Position Title: Technical Support Engineer
Country: Indonesia
Post by Darul Ikhsan »
Have you upload the local coordinate system into R8 receiver? As I know that we need to upload the local coordinate system into R8 receiver to get the local coordinate on the VZ-1000 display.
goatroxley
Full Name: Mark
Hi Darul
Its works when connected to a TSC3 so im guessing the local coordinate systems is loaded. Ive emailed Riegl support so hopefully I hear something tonight.
joe.3dlm
Full Name: Joe Beeching
Company Details: GeoSLAM Ltd
Post by joe.3dlm »
Does the TCS3 display the local coordinates because it already knows the local coordinate system transformation perhaps? Or is it just held in the R8?
I'm wondering if the R8 is really outputting the Trimble-specific strings.
You could prove the R8 is outputting the correct strings by connecting it to a computer and using a terminal program (e.g. HyperTerminal) to read the strings being output. You should be getting, for example:
$GPGGA,115403.00,4839.59782607,N,01539.89477543,E,5,12,1.0,317.149,M,0.000,M,1.0,4095*79
$GNGST,115403.00,0.005,0.097,0.071,73.8,0.073,0.095,0.188*73
$PTNL,PJK,115403.00,120511,+391478.412,N,-49235.465,E,6,12,1.6,EHT+317.149,M*4D
$PTNL,PJT,DatumSevenParameters,M34 Austria Global *74
$GPZDA,115403.010,05,12,2011,00,00*51
$GNGSA,A,3,14,18,6,11,22,3,19,,,,,,1.6,1.0,1.2*28
The following fields (marked bold in the example) are used:
PTNL,PJK:
• Northing
• Easting
• Height
PTNL,PJT:
• Coordinate System Name
• Projection Name
Joe
Darul Ikhsan
Country: Indonesia
goatroxley wrote:
Wed Jan 30, 2019 9:12 am
Hi Darul
Yes of course the local coordinate will be correct using TSC3, becauce the coordinate systems is loaded/setting on the controller. to display local coordinate on the VZ-1000 display, you must load the coordinate systems into receiver, because the scanner is direct connecting to the receiver without controller.
goatroxley
Full Name: Mark
HI guys, turns out the R8 did not have the coordinate information loaded into it. I updated the R8 file using the Trimble Configuration Utility. (created new coordinate system then uploaded a DC file from a TSC3 which has all the local grid information). I then usde the GPS configurator tool to set the NMEA ports and the winflash utility to set the radio. Bit of stuffing about but its working now so all good.
Thanks for the help
joe.3dlm
Post by joe.3dlm »
Thanks for updating us and glad you got it working ;)
Return to “Riegl”
