Background color
Romuald
Full Name: CLAVE
Company Details: www.urbica.fr
Company Position Title: Project manager
Background color
Post by Romuald »
Is there any possibilites to change the backgraond color in Cyclone ?
Instead of black, I would like to change to an other color. Is it possible ?
I did not see the option in the preference.
Has thanked: 45 times
Been thanked: 37 times
Re: Background color
Post by Matt Young »
This is an easy one to miss as there are quite a lot pf preferences to look through in Cyclone.
I like to add a white background so I can make images that will be printed in AutoCad, very usefull.
TimBeach
Full Name: Timothy Beach
Company Details: Hollis
Company Position Title: Senior Associate - Measured Surveys
Has thanked: 4 times
Post by TimBeach »
Is there any reason why I cant do this when only running Scan/Register and Cloudworx Licences?
I only get the following Options
Although presumeably if i log into our server and the MODEL licence, make changes and set it to a default, it should stay that way regardless of which licence it is running after that?
Ive been wondering about how to do that for a while, mostly for Image Printing...
Thanks for that Tip Matt
Tim
I think that the option is limited to 'Model' Because of the visual aspect when viewing models, but I agree that it should be available in the even the viewer version, as well as things like limit box's etc.
Romuald
Full Name: CLAVE
Post by Romuald »
Matt Young wrote:This is an easy one to miss as there are quite a lot pf preferences to look through in Cyclone.
Yeah, that's it !
This preference is also usefull to generate Trueview with White background (or other to adapt to the graphic chart of the customer).
Romuald
TimBeach
Post by TimBeach »
A follow up Q.
Is it then possible to change the colour of the Fence?
As white on White becomes a challenge to know what you are fencing!!
Tim
Romuald
Full Name: CLAVE
Post by Romuald »
It is true, the background white is more for copy screen or generation of the TrueView index page. It is not possible to work with the fencing white.
Full Name: Dany Lachance
Company Details: distributor and technical support
Company Position Title: Tech Support
Post by [email protected] »
Could it be possible to change the interface color, to be like darker juste like register 360?
