Existing Revit model crashes when insert Edgewise Model
Discuss all ClearEdge3D related issues here.
benzilliox
Full Name: Benjamin Zilliox
Company Details: KLH Engineers
Company Position Title: CxA
Skype Name: Ben Zilliox
Post by benzilliox » Thu Nov 08, 2018 3:41 pm
I have and existing Revit project that our designers are working and we tried to insert the exported Edgewise model into Revit and Revit crashes. I spoke with Edgewise support and everything seems to be okay on the Edgewise side and i agree with that because the exported model was saved as a .rvt file and came in fine in its own model in revit. Just wondering if anyone else has experienced this and if so how they fixed the issue.
Thanks in advance for any suggestions.
Ben
neeravbm
Full Name: Neerav Mehta
Company Position Title: CTO
Re: Existing Revit model crashes when insert Edgewise Model
Post by neeravbm » Fri Nov 09, 2018 6:26 am
When Revit crashes, it send logs to Autodesk. Before it sends these logs, a popup shows you where these logs are stored on your drive. A couple of these files are text files. Can you send these files? In most cases, these will be useless to us but I have sometimes seen some errors which might suggest what's going wrong.
Neerav Mehta
CTO, Indoor Intelligence
Return to “ClearEdge3D”
