Cyclone Database-Scans not loading
bljbim
Full Name: Boyd Johnson
Company Details: URS
Company Position Title: Architect and BIM Manager
Post by bljbim » Thu Nov 08, 2018 4:01 am
New to Cyclone. Scanned with P40. Have about 40 scans. Each new scanner position was given a new Station ID under setup on the P40.
When I try and import a new project into Cyclone via Database...then load ScanStation Project and the .prj file, the import hangs for hours and hours - let sit for 8+ hours with no improvement in % complete.
After I force Cyclone to quit via "End Process" via Task Manager then restart Cyclone Navigator, all the SW files appear to load but it appears the actual scan files (.bin) didn't load.
Is there anything i am doing wrong? and/or any recommendations.
Also - Any good Cyclone Tutorials available on the web??? I would pay good money for one! Lynda has a FARO SCENE one, was hoping there would be a Cyclone one available as well.
The attached image hopefully explains the issues.
Thanks,
BLJ
tomii7
Full Name: Tomasz Gerlich
Company Position Title: Owner - 3D Laser Scanning Specialist
Country: PL UK International
Skype Name: tomek.gerlich
Re: Cyclone Database-Scans not loading
Post by tomii7 » Fri Nov 09, 2018 10:33 am
Hi Boyd,
On the network, we have some good tutorials.
You can go to this topic and Rob has posted some tutorials.
viewtopic.php?t=2087
- What's your spec of your machine?
- Where do you have a temp path?
- Also when you are importing the data, change from 'medium or low' to 'fast' and then your PC will use more resources.
Also Leica team ;-) is keen to help people. They have a very good support team!
Best,
TG
Best Regards,
Tomasz Gerlich
tomasz.gerlich[at]outputprecision.com tomaszgerlich[at]gmail.com
+44 7756613300
www.tomgerlich.com
steves01x
Full Name: Steve Smith
Company Details: Scanning
Country: Scotland
Post by steves01x » Fri Nov 09, 2018 12:16 pm
Long shot - but were you scanning on the advanced interface and not starting the next station properly?
As on your screen shot it looks like there are no scan files within each station in Cyclone but all the bin files in one scan folder - that means all the scans are in another set up in Cyclone, so look through all the set ups till you find all the scans! You will have to move each one to the correct folder manually in Cyclone.
** as above post says, Leica support is excellent!
tomii7
Post by tomii7 » Sun Nov 11, 2018 7:20 pm
thanks Steve;-)
BTW
the station seems to be split into smaller parts but also it might be everything ii one setup.
Moving manually scans in the cyclone is just only copy and paste, or moving.
Best Regards,
Tomasz Gerlich
+44 7756613300
www.tomgerlich.com
