URGENT help needed for scene
landmeterbeuckx
Full Name: Lieven Beuckx
Post by landmeterbeuckx » Tue Aug 28, 2018 6:23 pm
I'm on 6.2.2.7
I've got 3 clusters tied together locally. One cluster is done with spheres, the other ones c2c. The cluster with the spheres is the ref cluster.
When i insert 2 rtk points only the cluster with the spheres transforms, the c2c ones stay local.
This is driving me nuts. Does someone know a solution to place everything togheter fine. All scan managers are locked but the top one.
LSBbvba
Tel : +3211661621
www.landmeter-beuckx.be
info@landmeter-beuckx.be
brian715
Full Name: Brian Boehmer
Re: URGENT help needed for scene
Post by brian715 » Tue Aug 28, 2018 6:28 pm
From what I gather your structure should look like this to get the desired result.
CONTROL CLUSTER (DO YOUR REGISTRATION TO CONTROL HERE)
-CLUSTER 1(Registered your three clusters C2C) (LOCKED)
*TARGET REGISTRATION CLUSTER
*C2C CLUSTER 1
*C2C CLUSTER 2
You will probably need at least 3 control points from my experience.
landmeterbeuckx
Post by landmeterbeuckx » Tue Aug 28, 2018 6:34 pm
thanks a bunch. it bloody well worked.
i forgot one cluster.
you're a lifesaver
LSBbvba
Tel : +3211661621
landmeterbeuckx
Post by landmeterbeuckx » Tue Aug 28, 2018 6:36 pm
in scene it can be done with 2. It would be more accurate with 3 or more but scene has no geodetic module. It cannot calculate like a surveyor.
LSBbvba
Tel : +3211661621
brian715
Post by brian715 » Tue Aug 28, 2018 6:57 pm
Good to know that it only needs 2. Glad we could help.
Return to “FARO SCENE”
