Potree Issue
To chat about anything else.
gwhitch
Full Name: Gary Whitcher
Company Details: Blue Sky Evolution
Potree Issue
Post by gwhitch » Mon Aug 06, 2018 9:11 pm
Hello:
I have been using the Potree viewer and it has been going well until now.
On my test server, all works as it should. If I move those files over to my live server, the viewer opens but I have no cloud. I have checked to make sure the apppool has the correct privileges. I can't figure out why the same exact files work on one server and not another.
Any help would be appreciated!
max72
Full Name: Massimo De Marchi
Skype Name: massimo_de_marchi
Re: Potree Issue
Post by max72 » Wed Aug 08, 2018 10:20 pm
I have similar issues with clouds on a server. The clouds have been uploaded time ago and worked fine.
Now they are not working anymore.
I was wondering if the problem was server or client side... from your experience it looks like it’s server side.
VXGrid
I have made 70-80 posts
Full Name: Martin Graner
Re: Potree Issue
Post by VXGrid » Fri Aug 10, 2018 3:28 pm
I'd recommend to check the log file (the console of the browser, in firefox it is shift+F5) and see all outputs thrown by Potree after reloading the page.
Recently I ran into the same issue:
The error occured that the *.hrc files could not be loaded. This was depending with the server used (Microsoft server does not serve unknown mime types)
https://support.microsoft.com/en-us/hel ... mime-types
We added the Mime types for *.hrc files using:
https://stackoverflow.com/questions/678 ... my-program
Then everything worked fine.
gwhitch
Re: Potree Issue
Post by gwhitch » Fri Sep 28, 2018 8:25 pm
Hello:
UPDATE:
The issue on the live server was I forgot the MIME settings for the new Server (. (application/octet-stream) and .* (application/octet-stream))
Return to “General Chat”
