Scene to mesh
Raimund58
Full Name: Raimund Klink
Scene to mesh
Post by Raimund58 » Wed Jul 18, 2018 11:01 am
Hello friends,
I have a scanned turbine processed in scene. Now I want to make a high quality mesh model to use it for an animation. Can you help me with it?
How to export the point cloud effective?
In what program can I make a high quality mesh?
I also have ReCap.
Oliver Buerkler
Full Name: Oliver Buerkler
Skype Name: oliver_buerkler
Re: Scene to mesh
Post by Oliver Buerkler » Thu Jul 19, 2018 9:33 am
Hi Raimund.
Did you test SCENE´s built in meshing functionality?
If this is not sufficient for your needs, what requirements do your have in terms of the final mesh?
Best regards,
Oliver Bürkler
Oliver Bürkler
FARO Europe GmbH & Co. KG
oliver.buerkler@faro.com
Twitter: FARO_LS_PM
Raimund58
Re: Scene to mesh
Post by Raimund58 » Thu Jul 19, 2018 9:45 am
@Oliver Buerkler
Yes, I did a test in SCENE but the triangles are limited to 40000000. As I want to make a nice Video in the model/cloud I need a higher quality.
The final result should be "just" a pretty nice looking video :) The pointcloud is too "grainy"...
Raimund58
Re: Scene to mesh
Post by Raimund58 » Thu Jul 19, 2018 4:41 pm
I think, I have to play around with ReCap, Navisworks and SCENE more.
al1235783
Full Name: Phil
Company Details: Individual
Company Position Title: Individual
Re: Scene to mesh
Post by al1235783 » Thu Jul 19, 2018 8:11 pm
Hi Raimund,
We are using SCAN2FX Mesh Modeler. It's an add-on app that works within SCENE.
http://scan2fx.com/?id=scan2fx_mesh_modeler
Raimund58
Re: Scene to mesh
Post by Raimund58 » Thu Jul 19, 2018 8:30 pm
Thanks, I will try that
JackM
Full Name: Jack
Company Details: SpectisGB
Company Position Title: Technical Manager
Re: Scene to mesh
Post by JackM » Fri Jul 20, 2018 8:52 am
@Oliver Buerkler
Raimund, Have you tried using multiple clipping boxes in Scene?
I believe the triangle limit is only applied per clipping box so creating multiple and meshing each one will give you better results.
You can create a small box and right click on it to "create clipping boxes along an axis", after that you can create a mesh from each box and get a much better result.
Raimund58
Re: Scene to mesh
Post by Raimund58 » Fri Jul 20, 2018 12:57 pm
@JackM
Wow, I didn't knew that option, thanks a lot, it will be useful :D
Mrk
Full Name: Mark Lane
Company Details: Convert3D
Company Position Title: BIM guy
Re: Scene to mesh
Post by Mrk » Sat Jul 21, 2018 4:16 am
I take my clouds into Cloud Compare and use the poisson surface reconstruction - you can make the suface as detailed as your CPU can handle. Depending on the size, getting it into max may require sub-sampling though.
However, I understand Reality Capture has GPU support to accelerate the meshing process. Might anyone know if it's simple to export from Recap to RC?
caddrafting2013
I have made 100> posts
Full Name: Adam
Company Details: ADB3D Pty Ltd
Company Position Title: Director - Revit and Laser scanning
Re: Scene to mesh
Post by caddrafting2013 » Tue Jul 24, 2018 7:38 am
I create my mesh in cc then do a export/import to Revit and create my own families
Return to “FARO SCENE”
