Scanning Exeter's Underground Passages
THOR3D, Artec3D, ASUS Xtrion, Creaform G0-Scan, DotProduct, FARO Freestyle Noomeo, Mantis Vision, ZEB1, Kinect, DAVID, Effortless3D E3D Mk1, etc
Jamesrye
Full Name: James Rye
Post by Jamesrye » Fri Apr 13, 2018 9:55 am
I thought that I'd share a video animation that we made showing the medieval underground passages in Exeter. The passages were scanned with a Zeb Revo. The data was then meshed and loaded into Rhino3D where we created the flythrough.
youtu.be/Yg13fLP84T8
https://www.youtube.com/watch?v=Yg13fLP84T8
VXGrid
I have made 60-70 posts
Full Name: Martin Graner
Re: Scanning Exeter's Underground Passages
Post by VXGrid » Fri Apr 13, 2018 2:27 pm
Did you capture this with one go or did you make more loops?
How well is the trajectory? Did you compare the discrepancy of start and end point with outside measurements?
Looks like scanning with a Revo was a real time saver :D
Jamesrye
Post by Jamesrye » Fri Apr 13, 2018 3:09 pm
For sure it's a time saver! This was a demo - we were looking into the feasibility of using it for a mine project. We experimented with "there and back" loops as well as just going in one direction. There were limited places where we could do loops.
The passages are very narrow - in some areas you had to crawl and the passage was less than 0.5m wide. We did see some 'slippage' when fitting to control spheres that were shot in with a total station. Accuracy varied quite a bit, some runs fit well (better than 0.1m) and others were quite a bit off (metres off in some cases) - and some of the runs wouldn't process at all in GeoSLAM. The environment wasn't ideal for the scanner, though it was good enough for this presentation.
We subsequently used the Zeb-Revo on a building survey and we got data accurate enough for 1:100 drawings to be produced.
Return to “Hand Held Scanners”
