import Faro Scan to Leica Cyclone
365survey
Full Name: luigi Caputo
Company Details: land surveyor
Company Position Title: free lance
Country: Italia
Post by 365survey » Thu Apr 12, 2018 6:19 pm
Hello everyone, I'm new to the forum and sorry for my English.
I have a problem importing Faro scans into Cyclone.
I import the single Faro scans into Recap, export them as .pts and I import them in Cyclone, everything is ok but the scan center is placed higher than the real one of about 2-3 meters. I have done various tests but the result is the same.
thank you in advance.
Luigi
SAttaya
Full Name: Steve Attaya
Company Details: Geocent
Re: import Faro Scan to Leica Cyclone
Post by SAttaya » Fri Apr 13, 2018 1:04 pm
..., everything is ok but the scan center is placed higher than the real one of about 2-3 meters....Luigi
In my experience with FARO 120s, the "altimeter" readings
just are not accurate.
two scans from the exact same location 15 minutes apart
will have altitudes that vary by a meter.
365survey
Country: Italia
Post by 365survey » Fri Apr 13, 2018 6:55 pm
thank you SAttaya
the strange thing is that the center of four scans in Recap is correct, but the problem occurs exporting in .pts and then importing in Cyclone.
pbashiri
Full Name: Peyman Bashiri
Skype Name: pbashiri2003
Post by pbashiri » Mon Apr 16, 2018 4:04 am
As far as I remember you could import .fls files directly to Cyclone, you dont need to export it as a .pts and re import it to Cyclone.
Jamesrye
Full Name: James Rye
Post by Jamesrye » Tue Apr 17, 2018 3:50 pm
Luigi,
You may like to read through this thread:
viewtopic.php?t=12715
365survey
Country: Italia
Post by 365survey » Tue Apr 17, 2018 8:21 pm
thanks pbashiri
I will make a test
365survey
Country: Italia
Post by 365survey » Tue Apr 17, 2018 8:24 pm
thanks James
DanielNMP87
Full Name: Daniel Neagu
Company Details: XYZ
Post by DanielNMP87 » Tue Apr 24, 2018 10:36 pm
From what I understand the problem with imported fls in cyclone is that the SDK (level information- inclinometer reading) information from the Faro scans is getting ignored when importing so the scans get imported tilted... probably this will never get fixed....
Jamesrye
Post by Jamesrye » Wed Apr 25, 2018 8:51 am
At the recent HDS User Day, it was announced that there would be a fix for this importing issue. At the moment, the workaround we have is to import each scan to CloudCompare and then export it. It's hugely time consuming though, so we wont use a Faro again until Cyclone can import the data correctly.
365survey
Country: Italia
Post by 365survey » Thu May 03, 2018 8:27 pm
thank you all ... I see it's not just my problem :)
Return to “FARO”
