Clipping Scans for Edgewise
Discuss all ClearEdge3D related issues here.
rsivak
Full Name: Ryan Sivak
Company Details: BSI Engineering
Company Position Title: Process Designer - Lead Scanning Tech
Post by rsivak » Mon Mar 26, 2018 11:31 pm
Is there an easy workflow for clipping a scan file down before running it in Edgewise? For example, You want to only find pipe in the ceiling.
jmoranCE3D
Full Name: Jason Moran
Company Details: ClearEdge 3D
Company Position Title: Assistant Product Manager
Skype Name: edgewise.support
Re: Clipping Scans for Edgewise
Post by jmoranCE3D » Mon Apr 02, 2018 3:18 pm
EdgeWise does not contain any Point Cloud editing tools, so if you want to remove points from the cloud, it's best to do that in a registration tool before importing to EdgeWise. As long as the Row and Column Information and Scanner Location info remain in the scan, EdgeWise should process it fine.
If you're only interested in a few pipes, you may want to skip the Automated Pipe Extraction and open a Blank Pipe Model instead, then use the semi-automated Extract Tool (hotkey: X) to pick out just the pipes you need. Of course, in this work flow you will still need to create a Point Database, which can be time consuming on it's own. I would not recommend this workflow unless there truly are only a few pipes that need to be extracted, as it is much slower than the automated process.
brian715
Full Name: Brian Boehmer
Post by brian715 » Mon Apr 02, 2018 4:52 pm
We decimate the point cloud before importing into edgewise. It doesn't take very much data for edgewise to do its thing. We have exported every 10th row and column from scene and had no problems extracting walls in edgewise. It also makes the software run a lot faster especially if you are trying to import 300-400 scans at a time.
Return to “ClearEdge3D”
