LiDAR360 Version 2.1 available for testing
Download the latest software by clicking the links.
chenlinhai
Full Name: chenlinhai
Company Details: GreenValley International
Country: China
Post by chenlinhai » Wed Mar 14, 2018 9:12 am
Hi All,
The new version of LiDAR360 is ready to download, it provides tools for efficiently visualizing, generating & manipulating LiDAR point clouds. Analyze your data with TB level processing power. This comprehensive solution to post-processing LiDAR point cloud data includes industry specific modules which allows for a better user experience and quicker, more efficient results. The Terrain, ALS Forest, TLS Forest, Strip Alignment & Powerline Modules can be purchased separately or as a complete software suite depending on your company/project needs.
You may use this link to download the 30-day trial version, 30-day free trial including: Terrain, ALS Forest, TLS Forest & Strip Alignment. After 30 days LiDAR360 will continue to provide visualization and data management, absolutely free:
http://www.greenvalleyintl.com/software ... -downloads
Linhai Chen
chenlinhai
Country: China
Re: LiDAR360 Version 2.1 available for testing
Post by chenlinhai » Tue Mar 27, 2018 4:19 am
chenlinhai
Country: China
Post by chenlinhai » Tue Apr 17, 2018 2:59 am
New updates to LiDAR360:
1. Supports LAZ/LAS 1.4 file formats
2. Recognize intensity information with ply data
3. Stay tuned for updates to the TLS Module...
Download link:
https://greenvalleyintl.com/software/lidar360/
chenlinhai
Country: China
Post by chenlinhai » Mon Apr 23, 2018 7:21 am
Recently, the Geospatial Innovation Facility & IGIS are pleased to welcome Green Valley International (GVI) for a remote sensing LiDAR data acquisition and post-processing workshop.
youtu.be/UHIepjIZmvE
Full workshop available here: https://youtu.be/UHIepjIZmvE
chenlinhai
Country: China
Post by chenlinhai » Thu May 31, 2018 2:43 am
LiDAR360 software contains toolsets for efficiently viewing and manipulating point cloud data and offers modules for specific applications such as topographic modeling, forestry and in this case, power line analysis.
The Power Line module provides machine learning algorithms for automatically classifying ground, transmission towers, power lines, buildings, and vegetation. It is possible to simulate the influence of environmental variabilities along the corridor. It can also detect a range of user-defined hazardous points, such as vegetation overgrowth and tree fall, after which, will be included in a self-generated inspection report.
This article introduces the Qingyuan Power Supply Bureau of Guangdong Province, China utilized the GreenValley International workflow to carry out a risk assessment/management survey of over 2,500 kilometers of transmission lines (751km 500 kV, 1,824km 220 kV & 4,717 towers).
https://greenvalleyintl.com/application ... rne-lidar/
chenlinhai
Country: China
Post by chenlinhai » Wed Aug 15, 2018 10:02 am
LiDAR360 Version 2.2 available for testing, the download link for the trial version: http://www.greenvalleyintl.com/softwar ... ownloads/#
New Features:
Multi-threaded batch processing support
Measurement of individual tree attributes (total height, crown base height, stem straightness, diameter at breast height (DBH), etc.) from TLS data
Enhancements:
Improved regression analysis which allows for the importation of independent variables from external sources
Output elevation and intensity variables as .tif formatted files
Individual tree segmentation from a selected point cloud class
Improved TLS data editing tools that allow users to (1) batch process data to extract DBH measurements and (2) fit DBHs to point clouds selected in the profile view window
Add crown diameters, crown areas, and crown volumes to the outputs of the TLS individual tree segmentation tool
Functionality added to the Section Analysis Tool in the Terrain Module allowing users to now: (1) analyze .dxf formatted files, (2) import more than one file at a time and draw multiple section lines. (3) define a step value to simplify sections. (4) export multiple section files
Output contour feature as 2D polylines (.shp)
Edit for vector dataset attributes
Bugs Fixed:
Tree heights now updated for tree filtering after tree segmentation tool has been run
Projection information of las data can now be read
chenlinhai
Country: China
Re: LiDAR360 Version 3.0 available for testing
Post by chenlinhai » Mon Nov 19, 2018 2:05 am
LiDAR360 Suite v3.0 30 day free trial of the LiDAR360 software suite including:
Framework
Terrain
ALS Forest & TLS Forest
LiMapper (Photogrammetry)
LiGeoreference (Contact us <info@greenvalleyintl.com> for a free trial)
LiPowerline (Contact us <info@greenvalleyintl.com> for a free trial)
After the 30 day trial, LiDAR360 will continue to function as a free visualizer.
Trial verison download link: https://greenvalleyintl.com/software/so ... downloads/
Return to “Software Download Links”
