Opening *.csf file format
To chat about anything else.
SolvoTek-TR
Full Name: S. B. Sayin
Company Details: Solvotek Engineering
Company Position Title: Director and Chief Engineer
Post by SolvoTek-TR » Fri Sep 15, 2017 3:36 pm
We've received a cyclone file with *.csf file extension, there are three files like:
filename.imp.001.csf
filename.imp.002.csf
filename.imp.003.csf
No matter what I tried I couldn't open these files. Does anyone know what is this file format and how it can be opened?
Thank you.
Bora
Rikore
Full Name: Bruce Yager
Re: Opening *.csf file format
Post by Rikore » Fri Sep 15, 2017 5:36 pm
I believe the .csf file can be opened in Photoshop. It is a Adobe file format.
SolvoTek-TR
Post by SolvoTek-TR » Fri Sep 15, 2017 5:53 pm
It's actually a Cyclone imp dataset split into three smaller parts. However I couldn't find the software to merge them. Thanks for your answer btw.
Phill
Full Name: Phillip Nixon
Company Details: SKM
Post by Phill » Sun Sep 17, 2017 9:33 am
The program you need is file splitter. Harks back to the day when deliverables were on 4gig DVD's, and you had to split your files so you could send them. I have attached a version, I am not sure I am allowed to, but they no longer supply it with the newer versions.
I have had trouble in the past bringing them back with the different versions, even though the version under about is the same, it had changed from one version of cyclone to the other. The attached one is from Cyclone 6.0, so see how it goes. If not let me know, and if you have roughly the history of the imp file (i.e rough year it was created) I can probably dig out the relevant version (I have the version that ran with Cyclone 5.2 stored somewhere for this reason).
Phill
SolvoTek-TR
Post by SolvoTek-TR » Sun Sep 17, 2017 6:38 pm
Phill,
Thank you for the information and exe file. As you said FileSplitter.exe can split and merge csf files, however the version you sent didn't work and gave an error as "Given block file D:\file.imp.001.csf was not created from" So I assume this was created with an earlier version. The file dates back to 2006.
Thanks.
Bora
Phill
Post by Phill » Mon Sep 18, 2017 9:06 am
Bora
Find attached the 5.2 version. The date on this one is Feb 2005 which roughly lines up with your date. Came up with a regedit error but seems to work fine after pressing ok.
Hope this helps. Let me know if it still doesn't work and I'll get some other ones, but it involves loading older versions on a virtual computer, so is a bit more time consuming.
Phill
SolvoTek-TR
Post by SolvoTek-TR » Tue Sep 19, 2017 6:50 am
Phill,
Thanks for the 5.2 version, it worked. Even though I worked with Cyclone so long I didn't have the setup archive. It's strange that they changed the FileSplitter with different versions of Cyclone.
Again, appreciated very much.
Bora
Return to “General Chat”
