Easiest way to get images out of an E57 file?
ziltoid
Full Name: Gudmund Obrestad
Company Details: www.NTNU.no
Country: Norway
Post by ziltoid » Wed Apr 12, 2017 10:00 am
Hi. I have an E57 file that has 18 scans in it. I would like to use the images that are in the file for texturing. But I get an error in 3dreshaper when I try to load the file, and when I tried to export the images from scene I got the pointcloud in the images. What I want is to just have the images exported, or maybe seperate the file into 18 E57 files, so that maybe 3dreshaper can load them.
What I would like ideally, is to have the scanner positions made into spherical cameras in a 3d package, so I can use camera mapping for texturing. But that seems hard to do. Only way I know is to use Mari, and I have never used that program.
max72
Full Name: Massimo De Marchi
Skype Name: massimo_de_marchi
Re: Easiest way to get images out of an E57 file?
Post by max72 » Wed Apr 12, 2017 1:08 pm
From scene you can force to export to separate E57 files. It might be enough..
max72
Post by max72 » Wed Apr 12, 2017 1:15 pm
by the way.. are you sure you have the images in the E57? Is importing the FLS files an option?
ziltoid
Country: Norway
Post by ziltoid » Wed Apr 12, 2017 2:02 pm
I got the file as a Recap project, so I only have the images in Recap, and in exported E57 files. If there is a way to extract them in Recap, that would be neat.
I will try to delete all but one position in Recap, and see if that works.
I think that if I export the scan position as a dxf point, then I should be able to do it in 3ds max. Just apply the material with spherical mapping, and snapping the pivot of the gizmo to that point. Anyone tried that?
gilles_3Dreshaper
Full Name: Gilles Monnier
Company Details: Technodigit
Post by gilles_3Dreshaper » Wed Apr 12, 2017 8:13 pm
Any chance you can send the e57 file to our support team so that our dev team can have a look?
This is typical workflow for 3dreshaper...
Thx
Gilles
3DReshaper Manager
http://www.3dreshaper.com
Ryan
Full Name: Ryan Frenz
Company Details: Autodesk
Post by Ryan » Wed Apr 12, 2017 10:00 pm
ziltoid wrote:Hi. I have an E57 file that has 18 scans in it. I would like to use the images that are in the file for texturing. But I get an error in 3dreshaper when I try to load the file, and when I tried to export the images from scene I got the pointcloud in the images. What I want is to just have the images exported, or maybe seperate the file into 18 E57 files, so that maybe 3dreshaper can load them.
'Complete' E57 export in ReCap Pro should contain the spherical images, or at least sufficient data to recreate them. I have no idea what E57 variants are supported by Reshaper, however.
-Ryan
ziltoid
Country: Norway
Post by ziltoid » Wed Apr 12, 2017 10:45 pm
The E57 files from Recap has the images, but the files don't work in 3dreshaper.
I sent a link to the file to support as suggested, hope they can figure it out.
gilles_3Dreshaper
Post by gilles_3Dreshaper » Thu Apr 13, 2017 11:33 am
Hi Gudmund,
I had a look at the E57 file you shared.
As far as I can tell, it contains the point clouds but no image...
You say it does contain the images, how did you check?
Gilles
3DReshaper Manager
ziltoid
Country: Norway
Post by ziltoid » Thu Apr 13, 2017 1:30 pm
Thank's for looking into it.
I can only see the images in Recap, but I took the E57 file into Scene and split it up, and when I import just a few of the 18 scans into Recap, I still see the images. So the images are there, I just can get them anywhere else.
Edit: I can see the images in Scene and LupoScan as well, but when I export them I get the points overlayed. So if I figured out how to avoid that, I would be able to get them exported .
Almudena
Full Name: Almudena
Company Details: Beca Ltd
Company Position Title: Surveyor Technician
Country: New Zealand
Post by Almudena » Tue Jul 04, 2017 3:17 am
I am trying to achieve exactly the same as you. I have an e57 exported with only images from Cyclone. And It has data but 3DRehsaper does not open the file. When I export both cloud and images, then I can see the point cloud with the colour applied. But I just want to have the images.
Almudena
