Creating Models from Pointclouds using Artificial Intelligence.
- dineshkimraj
- Full Name: Dinesh Kimraj
- Company Details: Facilities Construction Consultants Ltd
- Company Position Title: Senior Reality Capture Tech
- Country: Trinidad and Tobago
- Has thanked: 40 times
- Been thanked: 3 times
Good day all, I know that it is possible to automatically generate pipes from the point clouds using Edgewise. Is there any way of generating entire models using Artificial Intelligence? Had a prospective client mention that they may be pursuing this option.
- Mike Annear
- Full Name: Mike Annear
- Has thanked: 122 times
- Been thanked: 196 times
Re: Creating Models from Pointclouds using Artificial Intelligence.
Ah, the magical "Make Model " button !
I certainly hope it is a long way off, or I am out of a job
Mike.
Mike.
- Full Name: James Worrell
- Has thanked: 14 times
- Been thanked: 87 times
It is happening - nothing overly commercial yet.
Stamford have a classification system they were working on at least 3 or 4 years ago.
A mate of mine at SiteSee is doing it for telecommunication towers with antenna modelling etc.
Few years away - but assume it will happen.
- Full Name: Neerav Mehta
- Company Details: Indoor Intelligence
- Company Position Title: CTO
- Been thanked: 6 times
From what I understand, SiteSee was only doing classification using images and was not building 3D models. This was a few years back though so I could be wrong.
They use images and point cloud in the segmentation - full 3D etc. Various videos online that gives a hint at what is happening under the covers. Images also feed in to the rust analysis and are used in the overall user experience.
- Mike Annear
Seriously ?
Can it do this ?
Can it do this ?
- smacl
- Has thanked: 627 times
- Been thanked: 657 times
At a guess this is not far off at all but whether the computational cost will be worth the result is something else again. Finding known discrete objects in a large point cloud can be done using a CNN with decent training data. If you have 3DS or BIM models representing your object you can probably build artificial training data. Thing is that the processing time and cost could well be prohibitive where a large number of potential objects are involved. So something like pylons could be easy where you might be searching for a handful of possible known types and have models to compare them against. All man made objects over a certain size inside a room is a rather different proposition, Florent Poux's work is worth reading on this.
- dineshkimraj
This is interesting, most of our clients are in the oil and gas industry. So the models we usually deliver to them are whole offshore platforms or onshore facilities. So using AI to model this might be a bit of a stretch.smacl wrote: ↑Thu Dec 05, 2019 11:59 amAt a guess this is not far off at all but whether the computational cost will be worth the result is something else again. Finding known discrete objects in a large point cloud can be done using a CNN with decent training data. If you have 3DS or BIM models representing your object you can probably build artificial training data. Thing is that the processing time and cost could well be prohibitive where a large number of potential objects are involved. So something like pylons could be easy where you might be searching for a handful of possible known types and have models to compare them against. All man made objects over a certain size inside a room is a rather different proposition, Florent Poux's work is worth reading on this.
- Matt Young
- Honorary Member
- Full Name: Matt Young
- Has thanked: 45 times
- Been thanked: 40 times
AI (Artificial Intelligence) will not happen until we perfect HI (Human Intelligence). And we are a very long way off on HI at the moment.
The idea that we, the same beings that are f£*$ing this world to pieces can make a machine that is clever is so insane! its enough to make anyone cry.
- Matt Young
- Honorary Member
Sorry, I just had to come back to this because AI can't solve anything. We need to get up of our arses and do it ourselves or we will all die.
