3d view
- I have made 30-40 posts
- Full Name: Ron smith
- Company Details: 3d surveyscan
- Company Position Title: Directo
- Country: Uk
- Has thanked: 4 times
3d view
Hi All
i have just recently updated my laptop (Dell Precision) to windows 10. everything seemed fine until i came to using scene this week.
i am on scene 2019.2. My problem is when opening 3d view. scans are loaded but not visual in 3d view mode. To get them to appear i am having to right click a scan then locate it. the scan and any other scans loaded now appear. All seem normal then! However i like to use correspondence view to check my registration. again scans partly load as normal but do not appear in the 3d view screen. Unless i right click and locate a scan when they all appear. However if i need to move a scan to a new position the grab handles are not appearing on scan selection.
My laptop is running a NVIDIA Quadro KM3100 M card I have updated drivers checked NVIDIA manager settings e.g 3d gaming setting etc. I have been using scene on this laptop for the last 3-4 years with no problems.
Any help or suggestions much appreciated
- TommyMaddox
- Company Details: ONSITE3D
- Has thanked: 67 times
- Been thanked: 130 times
Re: 3d view
If you have brought in control points or applied control, your camera view may be pointing far away from your scans when the 3dview is first loaded.
When you open your 3d view, check the coordinates in the bottom right of the screen, then compare them to when you locate a scan.
- Country: Uk
Re: 3d view
Hi TommyTommyMaddox wrote: ↑Thu Nov 28, 2019 6:21 pm If you have brought in control points or applied control, your camera view may be pointing far away from your scans when the 3dview is first loaded.
No control has been added at this point! I have uninstalled scene and re installed it. I have now noticed after trying to produce scene to go the program is stalling on trying to create overview map?
- Full Name: Raimund Klink
- Company Details: IHM engineering GmbH
- Company Position Title: 3d scanning guy
- Has thanked: 193 times
- Been thanked: 25 times
Re: 3d view
Hi Ron,Ronsmith1960 wrote: ↑Thu Nov 28, 2019 9:33 pmHi TommyTommyMaddox wrote: ↑Thu Nov 28, 2019 6:21 pm If you have brought in control points or applied control, your camera view may be pointing far away from your scans when the 3dview is first loaded.
Can you please test this problem in another test project?
If you import only three scans into a new project, are you still experiencing problems?
Kind regards
Raimund Klink
\o/
- Full Name: Daniel Pompe
- Company Details: FARO
- Company Position Title: Team Lead Software Engineering
- Been thanked: 19 times
Re: 3d view
Hi Ron,
please check the position of the camera in the 3D view when opening and when locating a scan (position shown in status bar as "Pos: x y z").
If initially it is very large there might be an object (e.g. point) with very large coordinates so the camera is zoomed out very far to show the whole scene.
Daniel
Daniel
- Thanh cao
- Full Name: Cao Phuc Thanh
- Company Details: Star Global JSC
- Company Position Title: Applications Engineer
- Country: Viet Nam
Re: 3d view
I also think so. Scan's coordinate may be too largepomped wrote: ↑Fri Nov 29, 2019 11:37 am Hi Ron,
Daniel
- Country: Uk
Re: 3d view
Hi RaimundRaimund58 wrote: ↑Fri Nov 29, 2019 9:25 amHi Ron,Ronsmith1960 wrote: ↑Thu Nov 28, 2019 9:33 pmHi TommyTommyMaddox wrote: ↑Thu Nov 28, 2019 6:21 pm If you have brought in control points or applied control, your camera view may be pointing far away from your scans when the 3dview is first loaded.
Kind regards
Raimund Klink
Yes!! I have tried various test projects all with the same results.
Kind regards
Ron
- Country: Uk
Re: 3d view
Daniel
Hi Daniel
Attached an image showing project i am working on. You can see no 3d view image has appeared even though the scans within the cluster are fully loaded. The pos number Is very large on the status bar??
Regards
Ron
- Full Name: Simeon Herrod
- Has thanked: 73 times
- Been thanked: 110 times
Re: 3d view
We're having an issue where 6 of 20 scans will display fine in Quick view, but nothing is visible in 3D view. (Latest version of Scene).
Scans before and after are all fine, just a random in the middle of a job that don't display correctly.
Data has been sent to our vendor support team.
Re: 3d view
To check if it is a problem of large coordinates, open the 3D view and look at the camera position (see red circle in screenshot)
If you see very large coordinates probably an object below the scan in the hierarchy exists with large coordinates. You can double check this if you right click on the scan and select locate. The camera should be moved to the actual scan points. Only solution so far is to find the object with the large coordinates and delete it.You do not have the required permissions to view the files attached to this post.
