New Workstation
- Full Name: Ben H
- Company Details: Surveying Solutions Inc
- Company Position Title: Systems Engineer
- Country: US
Re: New Workstation
Agree'd on all points.
> Lastly, as scanners get faster I wonder whether more data is always better.
This. This is something that I just cannot gauge right now.
But I am still interested to hear about the platforms you other guys are using.
- James Hall
- Full Name: James E Hall
- Company Details: Dewberry Engineering Inc
- Has thanked: 5 times
- Been thanked: 37 times
Re: New Workstation
"What Intel givth Microsoft takth way." An analogous situation with Faster scanners and processing their out put. What is needed is enough info to get the job done pulse a little extra. You can decimate most of the data out of a Leica P50 down to what you get out of an Old scan station and be able to extract road and corridor information just fine. Do you really need so much data. Answer No. I need to get done in the field and in the office as efficiently as possible. I would rather use a C-10 then a RTC360 for most of my work. Because it gets done faster. Less time downloading, less time fixing bad registrations.
James
- Mike H
- Full Name: Michael H
- Company Details: CFM
- Company Position Title: Senior Surveyor
Re: New Workstation
What do you guys think of my new workstation quote for Autodesk Civil3d and Cyclone.
Xeon W-2125 4.0Ghz 4 Core
64gb Ram
Quadro P4000 8gb
Win10
2 - 1TB M.2 Nvme drives for OS and Projects
2 - 4TB HDD for storage and backups
Could I have the temp folders on the OS nvme drive and Projects and the second nvme?
64gb Ram
Quadro P4000 8gb
Win10
- smacl
- Has thanked: 627 times
- Been thanked: 657 times
Re: New Workstation
Not bad but a single 4 core / 8 thread Xeon may become a bottleneck on any routines that are heavily multi-threaded on the above setup. With the above spec it would be worth considering a motherboard with a 2nd CPU slot in case you wanted to improve on this in the future.Mike H wrote: ↑Tue Oct 29, 2019 11:24 pm What do you guys think of my new workstation quote for Autodesk Civil3d and Cyclone.
64gb Ram
Quadro P4000 8gb
Win10
- Full Name: Simeon Herrod
- Has thanked: 73 times
- Been thanked: 110 times
Re: New Workstation
We have it set up so OS is on one NVME SSD, Temp folder is on a 2nd, and Projects are on a 3rd. An older workstation needed a PCIE expansion card for the 3rd SSD, but our newer on has enough M.2 slots.
- Mike H
Re: New Workstation
We are limited to the Dell Precision Xeon. Would a 3.7Ghz 8 Core work better? Does the 4.5Ghz Turbo work in point clouds?smacl wrote:Not bad but a single 4 core / 8 thread Xeon may become a bottleneck on any routines that are heavily multi-threaded on the above setup. With the above spec it would be worth considering a motherboard with a 2nd CPU slot in case you wanted to improve on this in the future.Mike H wrote: ↑Tue Oct 29, 2019 11:24 pm What do you guys think of my new workstation quote for Autodesk Civil3d and Cyclone.
64gb Ram
Quadro P4000 8gb
Win10
- smacl
Re: New Workstation
The 4.5ghz versus 3.7ghz means a potential 21% speed gain across all operations if the processor can sustain this speed. Doubling the core count would potentially double the processing speed on processes that were multi-threaded, which is based entirely on how cyclone is implemented. If Precision with Xeon is what you're getting, I'd say the spec you've got seems fine. My personal choice would be higher core count but that's more to do with development work and the SCC point cloud engine.
- James Hall
Re: New Workstation
What Shane said is spot on. I would go the other way because I do more raw point cloud possessing with just cyclone. Fewer faster cores serve my use better. Many Cyclone operations are still single core and multi-threading helps not at all with those.smacl wrote: ↑Wed Oct 30, 2019 1:47 pmThe 4.5ghz versus 3.7ghz means a potential 21% speed gain across all operations if the processor can sustain this speed. Doubling the core count would potentially double the processing speed on processes that were multi-threaded, which is based entirely on how cyclone is implemented. If Precision with Xeon is what you're getting, I'd say the spec you've got seems fine. My personal choice would be higher core count but that's more to do with development work and the SCC point cloud engine.
James,
- James Hall
Re: New Workstation
Are you doing timed benchmarks with common operations? How is your setup's performance? It sounds like it should be supper fast.sim.herrod wrote: ↑Wed Oct 30, 2019 12:16 pmWe have it set up so OS is on one NVME SSD, Temp folder is on a 2nd, and Projects are on a 3rd. An older workstation needed a PCIE expansion card for the 3rd SSD, but our newer on has enough M.2 slots.
The built in I/O controller can have issues keeping up. That is one reason for having a PCIE expansion card, for the separate I/O Controllers.
James,
- gsisman
- Full Name: Steve Long
- Skype Name: gsisman1
- Has thanked: 767 times
- Been thanked: 148 times
Re: New Workstation
James/Shane or anyone,James Hall wrote: ↑Wed Oct 30, 2019 3:50 pmWhat Shane said is spot on. I would go the other way because I do more raw point cloud possessing with just cyclone. Fewer faster cores serve my use better. Many Cyclone operations are still single core and multi-threading helps not at all with those.smacl wrote: ↑Wed Oct 30, 2019 1:47 pmThe 4.5ghz versus 3.7ghz means a potential 21% speed gain across all operations if the processor can sustain this speed. Doubling the core count would potentially double the processing speed on processes that were multi-threaded, which is based entirely on how cyclone is implemented. If Precision with Xeon is what you're getting, I'd say the spec you've got seems fine. My personal choice would be higher core count but that's more to do with development work and the SCC point cloud engine.
James,
We are doing most of our processing in Reg360 which I thought used multi-threaded processing. And then Civil 3D 2019 with Cloudworks using Jetstream and LGS files
Would more cores be better. We have Lenovo Think Station C30 with 48GB & 72GB RAM & 16 & 20 Cores respectively on a Single processor but have another processor Slot available on the motherboard and 4 ram slots open. Nvidia K4200 Graphics cards.
1TB SSD for OS and Apps,2TB HDD for Temp
Using 1GB network connection to Synology NAS 48TB-8drive RAID 5 for import, Project storage, and Jetstream & LGS Projects
Have 10TB (of the 48TB total) iSCI drive partition on Synology connected through the Jetstream Enterprise server for Archiving
Looking to beef these up more.
Suggestions?
