Cloudworx for Autocad Plant 3D
dineshkimraj
4
Full Name: Dinesh Kimraj
Company Details: Facilities Construction Consultants Ltd
Company Position Title: Senior Reality Capture Tech
Country: Trinidad and Tobago
Has thanked: 40 times
Post by dineshkimraj »
Good day all, we have a client who would like a CADworx model to be converted to a Plant 3D model. They need the intelligence of the piping. Right now our option is to model in Cadworx and then import that model into Plant 3D and then model the piping there.
Does Leica have a Cloudworx plugin for Plant 3D? Hopefully we can model straight in Plant 3D.
If not, does anyone have any advice on the best way to go about this?
geomontgomery
Full Name: George Montgomery
Company Details: ECE Design
Has thanked: 20 times
Been thanked: 48 times
Re: Cloudworx for Autocad Plant 3D
Post by geomontgomery »
Hey Dinesh,
What you are looking for is Cloudworx for AutoCAD. It will run on top of AutoCAD, and you can run either Plant 3D or CADWorx with it.
dineshkimraj
4
geomontgomery wrote: Mon May 13, 2019 6:52 pm Hey Dinesh,
We have Cloudworx for AutoCAD. But there isn't the cloudworx tab in plant 3d like the one that can be seen in AutoCAD.
dineshkimraj
4
I just noticed that Cloudworx is supported for AutoCAD versions up to 2019, so I am going to install Plant 3D 2019 and see if this works.
dineshkimraj
4
dineshkimraj wrote: Tue May 14, 2019 2:59 pm I just noticed that Cloudworx is supported for AutoCAD versions up to 2019, so I am going to install Plant 3D 2019 and see if this works.
Ok so no progress. Does anyone have any advice?
Rlowry
Full Name: Russell Lowry
Company Details: Bi-Con Engineering
Company Position Title: CAD Manager
Post by Rlowry »
Have you tried running the menuload command and loading the Cloudworx.cuix file?
geomontgomery
Make sure you're trying to install Cloudworx 6.4.2 as well, prior versions may not install on 2019.
dineshkimraj
4
Rlowry wrote: Wed May 15, 2019 8:31 pm Have you tried running the menuload command and loading the Cloudworx.cuix file?
Hey that was a great suggestion. It loaded. But when I tried to to import a pointcloud it says it does not recognise the command.
Also, when I quit plant 3d and try to reopen it, it crashes.
dineshkimraj
4
geomontgomery wrote: Thu May 16, 2019 1:38 pm Make sure you're trying to install Cloudworx 6.4.2 as well, prior versions may not install on 2019.
Yup that's the version I have.
