RTC360 use the image to texture the mesh
marty
Full Name: David Marty
Company Details: Ig group SA
Country: Swiss
Post by marty » Tue May 14, 2019 9:13 pm
I'm looking for a big project in a church and I need to generate a mesh with the texture.
I vould like use the photo that are taken with the RTC360.
Somebody have already experience with that ? How should be export / use the photo from the RTC.
Other question : wich have experience with a good mesh software that are able to mesh a very big pointcloud. 3DReshapper are good but I think that we could found a better sofware, geomagic, ... ?
I have 3DReshapper
Best regards
David
TimJervis
Full Name: Tim Jervis
Company Details: Global Survey
Company Position Title: Business Development Manager
Country: New Zealand
Been thanked: 5 times
Re: RTC360 use the image to texture the mesh
Post by TimJervis » Tue May 14, 2019 9:35 pm
Hi David,
In 3DReshaper you can texture from an e57 or LandXML through the "Image" ribbon and selecting the "Texture Atlas" function. This will read the images from those files and texture the mesh with them - it works pretty well.
Not sure about other packages.
Hope this helps!
Tim
marty
Country: Swiss
Post by marty » Wed May 15, 2019 7:27 am
Hi Tim
Thank you very much for your answer.
I didnt' know that the image were stocked into the *.e57. I thought that only the points are colored in Cyclone with the image and then with the export on e57, the picture are lost.
all images are stocked into the e57 ?
i'm looking this solution and should be good. I'll ask a licence demo for a extend licence.
Bests regards
David
pburrows145
Full Name: Paul Burrows
Has thanked: 4 times
Post by pburrows145 » Wed May 15, 2019 9:53 am
Tim is correct - the images should come through into Reshaper from Cyclone with e57 files. You can also "Colour Meshes from points".
Here is an example I did with this option (rather than using the texture atlas): https://sketchfab.com/3d-models/fountai ... e88b22d7e5
Not as crisp as using the full resolution textures, but still a nice result...
pburrows145
Post by pburrows145 » Wed May 15, 2019 10:20 am
https://www.linkedin.com/feed/update/ur ... 4725422080
See this post from Nathan in the UK
marty
Country: Swiss
Post by marty » Thu May 16, 2019 6:03 pm
Hi
Thanks for the informations !
I'll tray in my next project
Regards
David
ericguizzetti
Full Name: Eric Guizzetti
Company Details: Construction and Engineering
Company Position Title: RealityCapture
Has thanked: 8 times
Post by ericguizzetti » Fri May 17, 2019 9:25 pm
damn thats epic
Eric Guizzetti
San Diego, CA
Insta: ericguizzetti
Linkedin - https://www.linkedin.com/in/ericguizzetti/
ericguizzetti
Post by ericguizzetti » Fri May 17, 2019 9:27 pm
I have 3DReshapper
Best regards
David
I just did the Seattle coliseum with the RTC360 and Nikon D850. Image quality is insane. You can zoom in and see every scratch. You might want to rent one.
Eric Guizzetti
San Diego, CA
marty
Country: Swiss
Post by marty » Mon May 20, 2019 1:35 pm
Hi Thank for the informations
But how do you combine the pictures with the Nikon and the mesh ?
Have you made a texture mesh ? If yes, it's possible to see an exemple ?
Best Regard
Groothedde-ing
Full Name: Pascal Groothedde
Company Details: Architectural engineering company
Country: the Netherlands
Post by Groothedde-ing » Wed May 22, 2019 1:39 pm
I'm also curious about the workflow of 3D reshaper and meshing RTC360 data with DSLR images.
