Leica Register 360 - z axis issue
boxel0
Full Name: Lewis Boxer
Company Details: Advanced 3D Laser Solutions Ltd
Post by boxel0 » Tue Oct 30, 2018 4:39 pm
Hi Guys,
We recently got the chance to have a play with an RTC360
We have ran all the files through the tegister 360 software, everything looked fine in the birdseye view,
But under closer inspection (using the trim view) i noticed that some scans were above others, but in the correct x & y
Any ideas, of how to fix this, I have tried splitting the project down into seperate bundles and then bring them together, but the issue returns
Lewis Boxer
Technical Director
e: [email protected]
w: www.lasersurveying.com
geomontgomery
I have made 100> posts
Full Name: George Montgomery
Company Details: ECE Design
Has thanked: 10 times
Been thanked: 10 times
Re: Leica Register 360 - z axis issue
Post by geomontgomery » Tue Oct 30, 2018 5:42 pm
In REGISTER360, highlight one of your red links, and press V to enter visual alignment. Click top view or side view to toggle between plan and elevation. You can dial elevation in when you're in side view. Here's a quick gif how that might work:
Direct link to gif here
jmeszar
Full Name: Jay Meszar
Company Details: IMAGINiT Technologies
Company Position Title: Senior Application Engineer
Post by jmeszar » Sat Jan 12, 2019 2:36 pm
This can also be accomplished in the field if you are using a tablet to assist in your scanning efforts. On the tablet in Cyclone Field, you can select a link and view it in elevation view and adjust the scan by dragging it up or down. I will follow up with pictures or a short video when i get my ipad close by.
steveholly
Full Name: stephen holly
Company Details: Pure Real Estate
Company Position Title: Architectural Technician
Country: England
Post by steveholly » Sun Jan 13, 2019 12:39 pm
We are also looking at the RTC to purchase. However, have concerns over z-axis tilting issues with it.
I believe it doesnt have a dual axis compensator like the P series, and wanted to know if anyone is aware of Z-axis issues when registering data with the RTC.
Any advice would be appreciated.
KR
Steve Holly
https://modellingarchitecture.co.uk/
SCCS RTC
Full Name: Phil Marsh
Skype Name: Phil.H.Marsh
Been thanked: 5 times
Post by SCCS RTC » Sun Jan 13, 2019 6:57 pm
KR
Steve Holly
I’ll give you a call tomorrow ;)
M: 07540 201383
E: [email protected]
W: www.sccsurvey.co.uk
Mrk
I have made 70-80 posts
Full Name: Mark Lane
Company Details: Convert3D
Company Position Title: BIM guy
Post by Mrk » Sun Jan 13, 2019 11:29 pm
I've encountered the z-axis issues as well. It seems to occur mostly in small rooms, stairwells in particular - the result is that the scan z-axis comes in to Field360 at an inclined angle at 30-60 degrees.
Firmware & Field360 updates still haven't fixed the problem which costs us a lot of time onsite to manually correct on the ipad, or extra office time to fix in Register360. However, even with the z-axis problems, the scanner still finishes the job faster than a P-series.
Leica don't seem to have any solutions, so I'm keen to hear some suggestions as well.
Has thanked: 49 times
Been thanked: 11 times
Post by gsisman » Mon Jan 14, 2019 10:33 pm
We have also ran into some z-tilt issues for no apparent reason, except also the small stairways (one had a half-circular back wall) and another when we did a 90 degree tilt scan (scanner horizontal) followed by a moving to another vertical scan using the VIS to maintain differential x-y-z
One of the nice things about Cyclone Field 360 is that it has a VERTICAL rotation ability in it's visual alignment that IS NOT in Register 360. In fact that tool in Register 360 only rotates the elevation view in the x-y plane. And even though you can orbit in the elevation view when you go to shift up and down- the view snaps back to the original orientation. This is not the case in Field 360 , which holds the position of you ordbited view while allowing you to shift up and down- it is more than irritating in Register 360 that lacks this. The latest version 1.5.1 has no resolution to this yet.
BrendanL
Full Name: Brendan
Company Details: Landpartners
Post by BrendanL » Fri Feb 01, 2019 12:11 am
I've encountered this on a particular job measuring internals of a building, it would happen fairly consistently when entering small unlit bathrooms. I believe it is VIS lock failing for a brief moment, then re-engaging while still in motion(Resets its z axis).
A workaround for this is to move into the room slowly and holding the unit at arms reach(To not block the VIS cameras). Will slow you down briefly and can be a bit awkward maneuvering it sometimes, but saves on trying to fix the wonky z rotation.
Also, z axis rotation would be nice in the desktop apps too
mlarson
Full Name: Mike Larson
Company Details: ___________
Post by mlarson » Wed Mar 27, 2019 7:08 pm
Is the only way to rotate these scans then in Cyclone Field 360? So I would have to load the scans back onto the RTC360?
Or is there a way to adjust the rotational axis when adjusting scans in the elevation/side view using Cyclone Register 360?
Post by gsisman » Wed Mar 27, 2019 7:34 pm
Mike
Yes you can correct it in Reg 360 by using the split view and pick points (3 or more) to align the scans. Depending on how far out it is tilted, until they come out with the vertical rotation in Reg 360 You have to use split view.
It's important that your first scans are pretty level. We noticed that having a good level first scan is helpful to build off of.
Return to “Leica Cyclone”
