Inverting Laser Scanners
Please post any tips or advice you have in general relating to laser scanning either whilst onsite or office based.
SCCS RTC
Full Name: Phil Marsh
Skype Name: Phil.H.Marsh
Been thanked: 20 times
Post by SCCS RTC »
I thought I'd create this post as I'm seeing lots of people on LinkedIn post images of their inverted scanner setups with the kit been hung upside down by the tribrach. :o
Like this....
I would personally use the Nedo Invert Shaft Tripod - https://www.sccssurvey.co.uk/industrial ... ripod.html with the special adapter that fits most scanners....
And this is how to use this adapter which bolts to the base of the scanner....
I'm sure there are others on the market and I'd welcome knowledge of these products.
M: 07540 201383
E: [email protected]
W: www.sccsurvey.co.uk
steves01x
Full Name: Steve Smith
Company Details: Scanning
Country: Scotland
Has thanked: 16 times
Been thanked: 17 times
Re: Inverting Laser Scanners
Post by steves01x »
How much is the adapter for the P40?
Already have that tripod, so handy when on site to go back round a job filling in gaps with the high set ups!
SCCS RTC
Post by SCCS RTC »
steves01x wrote:
Sun Feb 17, 2019 12:57 pm
Hi Steve,
The adapter is for sale here - https://www.sccssurvey.co.uk/adapters-f ... nners.html
Send me an email and I'll give you some discount.
M: 07540 201383
Chris06
Full Name: Chris
Company Details: Not Applicable
Company Position Title: Not Applicable
Post by Chris06 »
A few years ago I built a rig to hold our P40 over the top of stuff, then Leica updated the firmware to increase the vertical FOV and I don't think we've used it since :lol:
FOSI17
Full Name: LUIS COSTA
Company Details: GEOTRILHO
Country: Portugal
Post by FOSI17 »
Don't use the tribrach. The 3 pins on the bottom of the P40 will start to slide out eventually.
shollinger70
Full Name: Stephen Hollinger
Company Details: HGA
Company Position Title: 3d tech manager
Post by shollinger70 »
Recently purchased this setup and it worked flawlessly in the field. The cost of the adapter is well worth the piece of mind.
cpw006
Full Name: Chris Widmer
Company Details: LAS
Company Position Title: 3D Scanning Manager
Has thanked: 3 times
Post by cpw006 »
We have this tripod and only invert our FARO scanner, we are too nervous to invert the P40. If we did have to invert the P40 then we would purchase that adapter as well.
chapmandu
Full Name: Jon Chapman
Company Details: RA Smith National Inc
Post by chapmandu »
Phil,
We purchased this adapter from Leica / Z&F for inverting our HDS 7000 some years ago.
From what you are saying, it sounds like we would need to buy the Neno adapter, and then specify the 660041 (for the 7000) in order to use this the proper way. Or is this plate what you get (in part) when you specify 660041, and perhaps could we then specify the 660042 for our P series scanner and then be set up to invert both scanners?
Also, do you know if they make an adapter for the RTC 360 for this inverted setup?
Thanks,
Jon
Chris06
Full Name: Chris
Post by Chris06 »
I should have mentioned, our rig uses an adapter which looks something like this...
Phil Marsh
Skype Name: phil.h.marsh
Has thanked: 32 times
Been thanked: 13 times
Post by Phil Marsh »
That is the permanent mounting adapter sold by Leica.
LASER SCANNING FORUM
Return to “Tips & Advice”
