I have an interesting issue to solve which folks might have some ideas for the best way. I have a scan project of a warehouse with round columns. I’d like to extract the center point coordinates of each column (close to the base) using only SCENE and/or a free SCENE app.
I haven’t found a way to identify the center of a circle in SCENE and I want to find such coordinates so I can adjust the rotation prior to exporting the project to Recap.
Any ideas are appreciated.
SCENE Center of Round Columns Problem
- MarkL
- Full Name: Mark Lupton
- Company Details: Wolverton
- Company Position Title: LASER Scanning
- Skype Name: [email protected]
Re: SCENE Center of Round Columns Problem
I haven’t ever used it, but I think scene can make cylinders from the points. That’d give you the xy of the central axis.
- I have made 60-70 posts
- Full Name: Tom Elbich
- Company Details: Solid Ventures Inc
- Has thanked: 9 times
- Been thanked: 5 times
Yes, thanks. I forgot about Pipe Fit tool. It's a little tedious and I see you should have a good Quick View of the column to be able to pick the points, but it does give you the axis.
- LPaulCook
- Full Name: L Paul Cook
- Company Details: Land surveyor doing LiDAR
- Has thanked: 47 times
- Been thanked: 44 times
You can use a clipping box to look inside the outside edge then dimension the diameter then set a point on the center of the dimension line which is where the distance bubble is connected to the diameter distance line as that is the radius point.
L. Paul Cook, PLS
www.LPC3D.com
www.LPC3D.com
- Full Name: Scan ku kaï
- Company Details: Scankukai
- Company Position Title: CEO
- Country: France
- Has thanked: 58 times
- Been thanked: 207 times
We developed a plugin called "Extended toolbox". You can create circles and extract the center automatically.
You can force the circle to be horizontal.
We offer a free 3 days trial. This toolbox includes over 10 features.
