Cyclone 9.3.2 or any 9.x.x amount of scan files fails
dapo
Full Name: daniel poidevin
Company Details: Latinco SA
Company Position Title: Topografo
Country: Colombia
Post by dapo »
Regards
Some know how to solve this problem with cyclone:
I create a database and when importing any scan of my p40 to cyclone the progress bar does not advance and after a few minutes it closes.
I open cyclone again, check and import the folders but empty without registration without points without anything.
I've already reviewed. I thought it was the scaner but there are old scans that I had already worked and could open and process and try to import them again it's the same. I need to make a delivery and I can not work
here video
https://youtu.be/wf_ENP7C94I
dapo
Country: Colombia
Re: Cyclone 9.3.2 or any 9.x.x amount of scan files fails
Post by dapo »
Yuelin
I have made 90-100 posts
13
Full Name: Yuelin
Company Details: Leica Geosystems
Company Position Title: Lead software engineer
Been thanked: 11 times
Post by Yuelin »
Hi Daniel,
Please check if you have adequate space for the temp folder and database file.
You can also try to partial import single setup each to narrow down which setup is causing the problem.
dapo
Country: Colombia
Post by dapo »
regards
on the hard drive I have enough space, where the temporary folder is located there are 75gb free and where we store the gross scaneos there is 100 gb
My PC has the following features:
core 7 (6700) HQ
16 gb ram ddr4
250 GB DD in solid state (operating system)
1 TB DD
Nvidia geforce 960m 2gb DDR5
excuse my english use google translator
dapo
Country: Colombia
Post by dapo »
other video here
https://youtu.be/hhptQUfixu0
I import a single scan of a large file, and load the record but not the points I do not see the cloud at the beginning I throw an error that said that the had no valid points in the video is not but it came out in the tests I do, it seems that the error is when reading the clouds
Rikore
8
Full Name: Bruce Yager
Been thanked: 7 times
Post by Rikore »
Daniel,
The 75GB may not be enough. Three to four times for the temp file over the scans. So if what you are importing is over 25GB, that may be the reason.
steves01x
8
Full Name: Steve Smith
Company Details: Scanning
Country: Scotland
Has thanked: 31 times
Been thanked: 57 times
Post by steves01x »
Is your machine on a network with various security software running? And do you have external hard drives plugged in to the usb ports? I know both of these can cause Cyclone issues!
dapo
Country: Colombia
Post by dapo »
regards
there are no external connected or dd usb, the file I try to import weighs 5 gb but I have tried to import minors up to 700 mb but still fails the cyclone
steves01x
8
Country: Scotland
Post by steves01x »
Have you installed Cyclone on another PC and tried?
Are you sure the raw data is not corrupt?
Thomas Goodliffe
15
Full Name: Thomas Goodliffe
Company Details: Thomas Goodliffe Surveying Limited
Post by Thomas Goodliffe »
Hello, I wonder how did you resolve this as we are having the same problem importing p40 data? Latest version of cyclone closes and only first scan or first few scans import with a modelspace, no registration etc. Loads of hard disk space available in comparison to the data folder size. Thank you. Tom
Tom Goodliffe
Thomas Goodliffe Surveying Ltd
