Cyclone with RTC360
- stuartbuckett
- Full Name: Stuart Buckett
- Company Details: Water Corporation
- Company Position Title: Principal Surveyor
Cyclone with RTC360
Hey there
So i have the Shiny new RTC360 and Cyclone 9.3.1
And i have a huge problem, Cyclone develops a bug around 100 scans per registration where it slows down to snail pace.....
Before you ask yes i have a good Computer (7700K, GTX 1070, 64GB ram, SSD etc)
Ive never had this problem with P Series Scanners as i usually have IMP databases of over 1000 scans (1TB Plus)
The issue is mainly apparent when i got to add Scans to my registration via Visual Align, 75% of all my scans are target based registered and they come together no issue (300 scans registered in 30 mins) but when i start to add in the additional C2C scans it take upwards of 15 minuets per scan....
Any ideas and anyone else having this issue?
As a 10 year user of Cyclone and Leica scanners this has me stumped.....
And i need a solution fast as our typical project is 1000 scans and up... i have one project coming up with an estimated 8000 scans
- stevenramsey
- Full Name: Steven Ramsey
- Company Details: 4DMax
- Skype Name: steven.ramsey
- Has thanked: 30 times
- Been thanked: 72 times
Re: Cyclone with RTC360
I have seen the same issue with visual alignment if you have a reg with either lots of scans or lots of constraints after verifying the VA Cyclone takes an age to bring up the VA page. Like its flicking through each scan or each constraint.
- stuartbuckett
- danielgadowski
- 15
- Full Name: Daniel Gadowski
- Company Details: Transport for London
- Company Position Title: Senior Engineer
As a work-around I suppose you can find the point at which things slow down, create multiple registration up to that number that can be easily merged and then make a new registration by importing others in?
- I have made 50-60 posts
- Full Name: Jon Adams
- Company Details: Forensic and Architectural Consulting
- Company Position Title: Director of 3D Reality Capture
Have you tried registering the data in REG 360?
Sent from my SM-N950U using Tapatalk
- gsisman
- Full Name: Steve Long
- Skype Name: gsisman1
- Has thanked: 767 times
- Been thanked: 148 times
NEW FIRMWARE UPDATE AS OF TODAY?
MIGHT FIX THE PROBLEM.
https://laserscanningforum.com/forum/vi ... 46&t=13978
- stuartbuckett
The New firmware for the RTC seems to fix the issues i was experiencing with the scanner and the new version of cyclone fixes the exporting color issue.
Still massive issues with cyclone being unreliable when working on large size database's ie anything above 100 scans.
- James Hall
- Full Name: James E Hall
- Company Details: Dewberry Engineering Inc
- Has thanked: 5 times
- Been thanked: 37 times
For general prominence on work stations with an SSD hard drive.
Change the "page file size". Set it up to you physical memory size.
You can also put the page file on a serrate SSD to limit read/ write latency. Even better on separate BUS, like your OS one an M.2 and the page file on Sata III.
This might help with getting your remaining 100+ scan job registered.
James,
James,
- Matt Young
- Honorary Member
- Full Name: Matt Young
- Has thanked: 45 times
- Been thanked: 40 times
Personally I have found that setting the page file manually can lead to problems at some point. Much better to let the system manage the size. Just make sure you have a large drive with never less than 25 to 50% free. Keep on top of drive maintenance, such a defraging on regular basis and you should be fine.
- James Hall
Be careful defraging an SSD. The conventional wisdom is it dose not need to be done and even defarg utilities supporting SSD don't do much.
One of the few articles I have found that did actual testing. Stated it is best to let the SDD garbage collection routine take care of it.
https://www.pcworld.com/article/2047513 ... r-ssd.html
