Points appears again after cleaning
- I have made 50-60 posts
- Full Name: Jakub Kałaska
- Company Details: Geodezja3D
- Country: Poland
- Has thanked: 17 times
- Been thanked: 7 times
I created project point cloud than made some cleaning which was of course time consuming.
After cleaning up the project all the points I deleted appared again...
I tried another time, cleaned and saved and after opening project point cloud every single point I cleaned is still there.
Other issue. After updating point cloud almost all disapear (big cubes instead of points on the screen).
Any solution to avoid this problems?
- Felix_the_Cat
- Full Name: Felix
- Company Details: Lockheed Martin
- Company Position Title: Senior Member Engineering Staff
- Been thanked: 26 times
Re: Points appears again after cleaning
Big cubes happens to me if the project point cloud creation gets interrupted or the scratch drive or destination drive gets full during creating.
You have to delete the points out of the clouds themselves using 3D or planar view if you want them gone for good. If you delete them out of the project point cloud only they just come back the next time you update the project point cloud.
- Country: Poland
Cleaned points should not appear unless updating project point cloud.
I can't imagine why they came back after saving or compacting project.
- I have made 100> posts
- Full Name: Iain Took
- Company Details: WMP
- Company Position Title: Dogsbody
- Country: United Kingdom
- Has thanked: 3 times
- Been thanked: 6 times
Edit....
Nevermind wrong software
- 3DForensics
- Honorary Member
- Full Name: Eugene Liscio
- Skype Name: eliscio
- Has thanked: 13 times
- Been thanked: 70 times
The project point cloud is an entirely separate entity and once you have deleted points, you must choose to Update by using the drop down icons under the project point cloud button in the Explore tab. Once you update, changes will be permanent. If you just save the project by hitting the save button in the top left, that does not save the edits to the project point cloud. It will save changes to raw scans and scan point clouds though...
Eugene
Eugene
- Country: Poland
Yes, that's sounds logical. But SCENE is not...
If I update point cloud after deleting points everything appears again or the cloud becomes several cubes instead.
Another issue (with scene 2018 if that matters):
I run function Clipping box -> Export 3D selection
It does not work property for the Scene export the whole cloud, not the selection! I wonder it's 2018 version issue only.
I get mad with this software almost every time I open it.
- 3DForensics
- Honorary Member
There is either a bug or you are not updating the project point cloud directly. Just to conifrm, make sure you are not "saving" and updating from the "Project Point Cloud" icon in the Explore tab. That should fix it. Should that not be the case, then there is clearly something wrong.
With respect to the export, if you select a clipping box, right click and then choose Active Clipping Boxes, you can export what is inside the box from there.
Eugene
Eugene
- Full Name: Andrew Russell
- Company Details: Law Enforcement
- Company Position Title: Forensics
- Country: Aus
Hi Eugene
Just read the post can you confirm the way you explain to update the PPC directly please?
I am having similar issues with points remaining after clean up and exporting RCP format
Do you mean when you save there is a tick box to update the PPC ?
I know you mention not to use the update option in the explore tab?
- 3DForensics
- Honorary Member
Use the uption to update under the PPC icon in the Explore tab. That should take care of itQ
- Country: Aus
Hi Eugene
I tried that update but RCP seems to still export all the unwanted points and the whole project after clipping? I did post on here to see if anyone else had a fix but had no answer?
SCENE used to export the RCP file fine with the laterations as WA Police were having the same issues with SCENE since the 6.0 update?
thanks
thanks
