Data cleaning...what is the best method?
Jonny5isAlive
Full Name: Jon Adams
Company Details: Forensic and Architectural Consulting
Company Position Title: Director of 3D Reality Capture
Post by Jonny5isAlive » Wed Sep 12, 2018 1:46 pm
Just wondering what people are doing to clean datasets of unwanted noise/vehicles/pedestrians.
When we get into "busy" (urban) areas, cleaning time can slow to a crawl in Cyclone. Cleaning can take hours, waiting on selections/deletions to update.
We usually try to avoid unifying prior to cleaning, as it is often beneficial to be able to isolate clouds during the cleaning process.
We are working locally, data stored on SSD, have 64GB RAM, and Intel Xeon CPU E5-2687W v3 @ 3.10GHz
Any ideas appreciated.
Thanks!
Tookie
Full Name: Iain Took
Company Details: WMP
Company Position Title: Dogsbody
Re: Data cleaning...what is the best method?
Post by Tookie » Wed Sep 12, 2018 2:27 pm
We unify then select the noisy area and use the flat surface tool to deselect the road surface.
I've made a training guide with this in if you need more detail.
Edited to add that we don't have big datasets but do have lots of people moving in them despite all my shouting :-D
Jonny5isAlive
Post by Jonny5isAlive » Wed Sep 12, 2018 2:30 pm
Sure, I'd love to take a look. Do you have a link?
Are you referring to "region grow smooth surface"?
Tookie
Post by Tookie » Wed Sep 12, 2018 2:54 pm
Yes region grow. I can email a copy of the guide if you PM me your email address.
Matt Young
Full Name: Matt Young
Company Details: Baker Hicks
Has thanked: 6 times
Post by Matt Young » Wed Sep 12, 2018 3:05 pm
Definitely agree with the above methods.
If you work with larger unified datasets then compression of the database is important from time to time when cleaning and re-unifying the data.
On the subject of noise, did you know that the new Leica RTC360 has a feature that automatically deletes noise from people or objects passing in front of the scanner. It takes a double scan and compares both to see what changed, then removes the noise.
If you want to make something simple, then take one thing away that still allows you to do the job. Don't add two more things, and say they both make it easier.
Jonny5isAlive
Post by Jonny5isAlive » Wed Sep 12, 2018 3:50 pm
Yes, I am aware. Considering this as well. Actually just ran across the a topic here from 2014 when this may have been first suggested! :D
So suggestions are:
Unify (Fast? Reduce?)
Clean
If slow, compact? Re-unify? (Fast?)
sreed
Full Name: Scott Reed
Skype Name: sabotva
Post by sreed » Wed Sep 12, 2018 10:37 pm
I have an App we developed to do in Scene/Faro what the RTC360 does by double-scanning. PM me if you are interested in a demo trial. The App is a plugin for Scene.
Has thanked: 5 times
Post by landmeterbeuckx » Thu Sep 13, 2018 7:54 am
@sreed : what is it called. Cannot find it immediately
Tel : +3211661621
www.landmeter-beuckx.be
dirtysouthsurveyor
Full Name: Brandon B
Company Details: BKF Engineers
Company Position Title: PLS Project Surveyor
Post by dirtysouthsurveyor » Thu Oct 04, 2018 7:35 pm
When you say "compact" are you referring to optimizing the database?
I had a 3 mile stretch of an extremely busy roadway that we scanned at night. It was a nightmare cleaning that thing up with region grow because of how quickly it would break the unification. I ended up sectioning off parts of the road with the limit box, flip to ortho profile few then fenced in everything approximately 0.1' above the surface and deleted inside fence.
In retrospect, i wouldn't have brought in every day of data into the same database. Definitely going to keep future projects in separate databases and then clean them as I go. Just not sure of how to register the clean scanworlds together...
Has thanked: 3 times
Post by gsisman » Thu Oct 04, 2018 11:13 pm
There is a great terrain modeling from Scan Cloud program called QT Modeler (John Hopkins Applied Imagery Lab). They have recently added this feature at our request and other miltary clients. The side profile-defined corridor width-polygonal clip box. Check it out. The next request is an E57 unified import-as it only accepts LAS & PTS format exports from Leica Products
http://appliedimagery.com/
Return to “Leica Cyclone”
