Battery not charging in dock
SauceySurveyor
Full Name: Con
Company Details: D B
Post by SauceySurveyor »
Hello!
One of our batteries for our faro focus will charge fine in the scanner but if we put it in the dock it won't charge.
Has anyone has anyone else had this issue?
Our other batteries charge fine on the dock.
Nickel1
Full Name: Nick Worrell
Company Details: Atlantic Laser Scanning Services Inc
Re: Battery not charging in dock
Post by Nickel1 »
Its the dock.
The docks go bad constantly.
They get almost a grand out of them as well. I suggest ordering one now because we have been waiting on the two we ordered for 5 weeks!
Nick Worrell
President
Atlantic Laser Scanning Services Inc.
Rental Provider of FARO 3D Laser Scanners
FARO Training
New Smyrna Beach, FL
(800) 955-3960
atlanticlaserscanning.com
WWilford
Full Name: Warren Wilford
Company Position Title: owner
Post by WWilford »
Before you buy a new one try this.
viewtopic.php?f=20&t=11291&p=60119#p60119
brian715
Full Name: Brian Boehmer
Company Details: Meridian Eng.
Company Position Title: LiDAR Technician
Has thanked: 12 times
Been thanked: 5 times
Post by brian715 »
we have used a pencil erase or similar something to clean the contacts of the battery before when we have had issues getting them to charge.
I have never had an issue with the X330 battery doc yet.
kastopek
Full Name: Kyle Stopek
Company Details: Collision Specialists Inc
Company Position Title: 3D and CAD
Post by kastopek »
I was mentioned in that previous post and have had success calling FARO directly. Worth a shot
Thanks,
Kyle Stopek
Collision Specialists, Inc
625 Green Street
Gainesville, GA 30501
1-855-CSI- 6776 Toll Free
770-287-8734 Office
770-287-8688 Fax
www.collisionspecialistsinc.com
yankoch
Full Name: Yan Koch
Company Details: TagLabs
Has thanked: 10 times
Been thanked: 38 times
Post by yankoch »
Sometimes the contact between the battery and the docks connectors is bad.
Here's a tip: listen to the transformer while charging. Push the battery. When really charging, the sound of the transformer changes (lower frequency).
Maybe the connectors are dirty. Use a special electronic cleaner.
And use an elastic around the battery and the dock to insure a good contact.
berdindc
Full Name: Dan
Company Details: Berding
Post by berdindc »
Common issue. One of our 2 docks is bad, can't seem to fix with the suggested methods. At the end of day, we charge one battery in the good dock and other battery gets charged directly in the scanner.
vjDub
Full Name: Tori Wilkinson
Company Details: Wessex Archaeology
Company Position Title: Geomatics Technical Manager
Post by vjDub »
A problem with the connecting pins is very common, but it sounds to me like your problem is one we've experienced and that's with the "hot shoe" (dock) itself. The motherboard I believe it was. It's expensive to replace but I someone that can fix it for you - send me a message if you want the details
helen_guryn
Full Name: Helen Guryn
Company Details: 3D crime scene reconstruction
Company Position Title: 3D Forensic Technician
Post by helen_guryn »
Funny enough, I noticed that when you push the battery all the way in, it wouldn't charge sometimes. Try pulling it slightly out (1 mm or so) and see if that solves the problem
SauceySurveyor
Full Name: Con
UPDATE:
So I have looked into it a little further and it only seems to work on any battery now if you push the battery up against it.
Return to “FARO”
