Hey Gilles,
See the attached screencast, I can't seem to add more than one item to the header.
https://knowledge.autodesk.com/communit ... cf73040b02
2018 Report Editor - How to
- Full Name: Andrew Roth
- Company Details: Kova Engineering
- Company Position Title: Technologist
- gilles_3DR
- Full Name: Gilles Monnier
- Company Details: Hexagon
- Company Position Title: 3DR Technical Manager
- Country: France
- Been thanked: 28 times
Re: 2018 Report Editor - How to
Hi Andrew,
I will ask one of our developer to contact you and understand what is happening.
- gilles_3DR
- Country: France
we think we have solved your issue Andrew.
Please get the latest version from our web site.
By default, several items are now created in the header.
Gilles,
There is something weird going on with this new report editor. It keeps adding chapters to the report, even after I delete them.
https://knowledge.autodesk.com/communit ... 7342c40b6f
- Full Name: David Winters
- Company Details: RM Surveys
- Company Position Title: HDS Surveyor
- Has thanked: 3 times
Adding to the report editor thread..
Is there a way of saving filled headers and footers with no scene data as an empty importable chapter for all types of scene data. I.E create a title block in a sense. Each time i try to save the chapter as a template the header/footers are not carried over when i import the template into a new file.
The template editor guide is not very clear in what it saves as a template.
Cheers,
David
Cheers,
David
- gilles_3DR
- Country: France
Hi David,
Headers and Footers are managed separately.
You can save your current header/footer (as well as assigning an existing template to the current report) here:
(choose "Add to library" to save the current header to the library of headers).
And then use it (either for this report only or for all next reports) You can also define your default header/footer here:
