Creating the Overview Map is failed using SCENE 7.1.
60037 is displayed on the message box as below.
Is this ERROR No?
What is meaning of error if so ?
Failed to Create the Overview Map
- Full Name: Yoshiyuki Yamamoto
- Company Details: Aichi Institute of Technoology
- Company Position Title: Associate Professor
- Country: Japan
- Full Name: Tori Wilkinson
- Company Details: Wessex Archaeology
- Company Position Title: Geomatics Technical Manager
- Country: United Kingdom
- Been thanked: 2 times
Re: Failed to Create the Overview Map
Check the 3D views of each individual scan - you'll probably find one is empty. We remove the data from mirrors using a distance filter, but if you make the selection then right-click outside the yellow area instead of inside it you can accidentally filter out the whole scan instead.
- Country: Japan
Hello, vjDub.
Thank you for your advise.
As you say, the Overview Map is done well by deleting scan which has no information.
Thank you.
Thank you.
- flohrd
- Full Name: Daniel Flohr
- Company Details: FARO
- Company Position Title: VP of Software Engineering
- Been thanked: 7 times
We will have a fix for this problem in the next service release for SCENE. The process of creating the overview map will be improved and this issue should no longer occur after the patch.
- I have made 60-70 posts
- Full Name: Sheartab
- Company Details: Arch Eng Design Firm
- Company Position Title: BIM Manager
- Country: US
- Has thanked: 11 times
- Been thanked: 6 times
Will we have the ability to create an overview map of a multi story building - by level?
- Full Name: Brian Boehmer
- Company Details: Meridian Eng.
- Company Position Title: LiDAR Technician
- Has thanked: 14 times
- Been thanked: 5 times
This would be great. Previously we have created a separate webshare for each floor and put them in the same folder so that they can be accessed from the same main screen, but having a built in way to achieve this would be ideal.
- Full Name: simon judd
- Company Details: Precision Air Surveys Limited
- Been thanked: 3 times
Multi Story Overview Maps can already be created in Scene and be exported to Websharecloud.
Once you have written the overview map, you can export the map at either Scan, cluster or project level. (right Click context and export Overviewmap).
If you have each floor in a main cluster for that building story you will then be able to export that overview map and re-import it as a layout plan, using the import parameters provided in the accompanying text file.
Write these out to websharecloud and they will appear in the bottom left hand corner under layouts.
This is the current process to use but as Daniel Flohr has advised I think this process will be improved in future release.
Simon
Simon
