Budget friendly pointcloud addon for Autocad
AutoCad, MicroStation, ZWCAD, ARES, GstarCAD, 4M, IntelliCAD Etc.
adam.lucivjansky
Full Name: Adam Lucivjansky
Company Details: Geoton
Country: Czech Republic
Post by adam.lucivjansky » Tue Jan 30, 2018 6:28 am
Hi colleagues,
I'm doing some research about softwares for pointcloud processing, I will need to create 2D building floorplans, elevations and sections from pointcloud data in Autocad. I know there is Cloudworx and Pointsense on the market and especially Pointsense looks pretty good from the videos I've seen so far but I'm little bit worried about price as I found it here: http://surveyequipment.com/kubit-pointsense-building/ being for sale for nearly £4000.... This is quite a lot for self employed person in central europe so I'm looking for more budget friendly alternative. It doesn't have to be too fancy, just containing basic funcionalities helping with pointcloud as using only native autocad is a bit painful.... Can you advice anything ? Thank you.
Adam
SCCS RTC
Full Name: Phil Marsh
Skype Name: Phil.H.Marsh
Re: Budget friendly pointcloud addon for Autocad
Post by SCCS RTC » Tue Jan 30, 2018 6:52 am
Have you been given a price for CloudWorx AutoCAD Basic yet?
M: 07540 201383
E: [email protected]
W: www.sccsurvey.co.uk
Mark Christy
Full Name: Mark Christy
Company Details: Veesus Ltd Arena4D.
Company Position Title: Technology Director
Post by Mark Christy » Tue Jan 30, 2018 10:21 am
Hi Adam,
Although it's not AutoCAD please check out Rhino CAD and our plugin for it (Arena4D.. www.veesus.com).
Rhino does produce AutoCAD compatible output and combined with our plugin is a very popular tool for creating architectural drawings from point clouds. The cost is also somewhat less!
Mark
Least
Full Name: Patrick
Company Details: 360G
Country: uk
Post by Least » Tue Jan 30, 2018 10:49 am
Undet is very good and very good value http://www.undet.com/software/pricelist-for-autocad-v2/
Simon Judd
Full Name: Simon Judd
Company Details: MALTBY LAND SURVEYS
Post by Simon Judd » Tue Jan 30, 2018 11:51 am
+1 for Undet we have 10+ Cad operatives using this all day everyday for our 2D and 3D Autocad workflow.
Easy to use, powerful and very cost effective
Works in Sketchup aswell!!
Aurelijus is the guy to talk to at UNDET
sersab
I have made 70-80 posts
Full Name: Sergio Sabbatini
Company Details: 3DScan it
Country: Italia
Skype Name: sersab
Post by sersab » Tue Jan 30, 2018 4:59 pm
Undet +1
Sergio Sabbatini
3DScan - 3D Laser Scanning and topography
T +39 039 6980186 | Mail [email protected] | Web http://www.3dscan.it/en/
tbwester
Full Name: Thad Wester
Company Details: WeWork
Post by tbwester » Tue Jan 30, 2018 5:53 pm
why not just use autocad?
SteveBury
Full Name: Steve Bury
Company Details: Bury Associates Limited
Post by SteveBury » Tue Jan 30, 2018 7:57 pm
Adam
By far the most cost effective option (because it’s free!) is this:
  • Download CloudCompare
    Bring in your point cloud (try keeping it fairly small if possible, particularly if your pc isn’t super powerful)
    It’s a good idea to rotate the point cloud so the sides of the building are ortho to the coordinate system - either do that when you process or in CC.
    Slice it to create views of your plans, sections and elevation
    View them orthogonally, then create raster images of each one (with a scale bar)
    Bring the images into CAD
    Scale the images so they are the correct size
    Draw over the top of them.
Even more cost effective is to use that technique with Draftsite which is a CAD software with exactly the same basic drawing commands as AutoCAD - it’s free for non-commercial use or $149 for the commercial version.
If you want to spend some proper money then PointCab allows you to do the same thing as the ortho images in CloudCompare, but is a lot more efficient, gives much better images, and has several other useful modules - it’s very much worth looking at.
Good luck.
cadmium
Full Name: Jason Bayer
Post by cadmium » Tue Jan 30, 2018 8:23 pm
using autocad by itself is fine.
you just slice the cloud for what you need.
worst case scenario is you add a couple lines.
max72
Full Name: Massimo De Marchi
Skype Name: massimo_de_marchi
Post by max72 » Tue Jan 30, 2018 8:57 pm
If you only need to create 2D drawings you have many options. Just a couple of suggestions:
- Autocad and Recap. If you have a recent Autocad version everything is already at your disposal. There are some bottlenecks but it comes at no cost.
- Pointcab (creates raster images as a base for your model to be inserted in Autocad)
If you are not sold to Autocad there is Rhino + Arena for Rhino. Cheaper and in my opinion way more effective. If you add visualarq you can do 3d BIM models. You can pair it wih Pointcab too.
Return to “CAD Software”
