Register 360 licence issues
graham.watson
12
Full Name: Graham Watson
Company Details: Road Science
Company Position Title: Technical Lead - High Speed Data
Country: New Zealand
Post by graham.watson »
Last week I updated to Cyclone 9.2 and also CLM 1.6. I also installed Register 360.
All was fine everything was working, until after using R360 and exiting, I could not access the Cyclone Register licence.
I kept getting the message licences in use, use in viewer mode. I checked the licence server and the licence was not in use. I got someone else to open Cyclone on a different PC. No problems.
I then reopened Register 360. This works fine. Closed 360 open Cyclone , no licence.
I spoke to our Rep, who hadn't heard of this.
I tried uninstalling Cyclone and 360 and the CLM and re-installing them. I still had the same issue 306 worked Cyclone wouldn't.
In the end I removed all my Leica HDS software, deleted all folders and removed all Leica references in the Registry.
I have re-installed Cyclone and all is good. I am a bit reluctant to re-install 360 until I know what might have caused this.
Anybody have any ideas. Spent a very frustrating day trying to sort this out.
graham.watson
12
Re: Register 360 licence issues
As an update, I have reinstalled everything and all is running smoothly.
Umberto
6
Full Name: Umberto
Company Details: Orienta + Trium
Company Position Title: HDS specialist
Country: Italia
Skype Name: Umberto Pavanello
Post by Umberto »
I unfortunately still have the same problem... I uninstalled everything and reinstalled... everything works except Register 360
Matt Young
Honorary Member
Honorary Member
16
Full Name: Matt Young
Company Details: Baker Hicks
Has thanked: 45 times
Been thanked: 40 times
Post by Matt Young »
It's likely that the process is still running in the background when one program closes.
Sharas
12
Full Name: Sharas Bandinskas
Company Details: Freelance
Company Position Title: Freelancer
Post by Sharas »
I had to update my CLM to make it work
Umberto
6
Full Name: Umberto
Country: Italia
Post by Umberto »
To make it work I always have to return and restore the licenses... and every Windows startup I have to repeat the procedure.... :shock: :? :(
