We’ve done a small scan job and processed the scans in Scene 7.0. Targets were used, measured with total station and manually registered.
Only two scans were done , the job processed and looks good in scene. Accuracy reports all ok.
The issue is when exporting as a single ptx and importing to Recap. The two scans are approx. ~1m apart horizontally.
If we export the two scans individually they both import fine.
Is this a scene issue or a Recap one?
Scene 7 ptx export
- graham.watson
- Full Name: Graham Watson
- Company Details: Road Science
- Company Position Title: Technical Lead - High Speed Data
- Country: New Zealand
- Country: Italy
- Has thanked: 15 times
- Been thanked: 53 times
Re: Scene 7 ptx export
Can you try to import the same files in another software?
Cloudcompare fo instance..
- 15
- Full Name: Ryan Frenz
- Company Details: Autodesk
- Company Position Title: Engineering Manager - ReCap
What version of ReCap? The only past issue I can think of is one about single-file PTX transforms and large coordinates (ReCap would cut digits/precision inadvertently). That was well over a year ago though.
If you aren't on a large coordinate offset (like more than 10km), or you're on a recent (4.0+) version of ReCap, this wouldn't affect you. In which case I don't think this is about ReCap, but would be happy to take a look.
-Ryan
-Ryan
- phamduysc
- Full Name: Duy Pham
- Company Details: Land Surveys
- Company Position Title: Project surveyor
- Skype Name: phamduysc
I've got this problem also. I had 24 stations, all registered with a good result in SCENE 7 but when I import the project to RECAP, they mess with each other. I had to re-registered again in Recap Don't know that's Recap or Scene 7 issuegraham.watson wrote: ↑Thu Sep 14, 2017 12:06 am We’ve done a small scan job and processed the scans in Scene 7.0. Targets were used, measured with total station and manually registered.
Duy Pham | Surveyor
- Full Name: simon judd
- Company Details: Precision Air Surveys Limited
- Country: United Kingdom
- Been thanked: 3 times
All
Have you tried exporting E57 format.
When importing the E57 to Recap skip the registration process and then index to RCS/RCP
This is a process we use on every project and never fails whether it is 2 scans or 3000 scans
Simon
Simon
- Full Name: Tim Bodor
- Company Details: Drafting + Design
- Full Name: debra
- Company Details: Tetratech
- Company Position Title: mech designer
Same here...scans are fine in scene and wonky in autocad or navisworksphamduysc wrote: ↑Fri Sep 15, 2017 10:03 amI've got this problem also. I had 24 stations, all registered with a good result in SCENE 7 but when I import the project to RECAP, they mess with each other. I had to re-registered again in Recap Don't know that's Recap or Scene 7 issuegraham.watson wrote: ↑Thu Sep 14, 2017 12:06 am We’ve done a small scan job and processed the scans in Scene 7.0. Targets were used, measured with total station and manually registered.
Faro says it's a "known" bug.
