Importing data captured with Pix4D into FARO Scene
- Full Name: Steve Smith
- Company Details: Engineering
- Company Position Title: Technician
I'm new to the group an am sure this topic has been covered. Is there a method to import pix 4D point data into Scene, and align the imported data.
- gordonired
- Full Name: Gordon
- Company Details: Roska DBO
- Company Position Title: GIS Coordinator
- Has thanked: 24 times
- Been thanked: 38 times
Re: Importing data captured with Pix4D into FARO Scene
I have not worked with Pix4D, but if you are trying to import a point cloud, Scene allows the import of .ptx, .pts, .xyz and e57 files. These will import, and you will be able to do registration. I've only used the older version of Scene (5.4), and in this version you need to jump through some hoops before you can register faro scans with external point clouds.
- Full Name: SAttaya
- Company Details: Sev1Tech
- Company Position Title: Sr Software Analyst-RemoteSensingEngr
- Has thanked: 127 times
- Been thanked: 17 times
as of 6.2.4.30, not PTS, maybe you meant PTZ.gordonired wrote: ↑Fri Jun 16, 2017 7:48 pm I have not worked with Pix4D, but if you are trying to import a point cloud, Scene allows the import of .ptx, .pts, .xyz and e57 files. These will import, and you will be able to do registration. I've only used the older version of Scene (5.4), and in this version you need to jump through some hoops before you can register faro scans with external point clouds.
- gordonired
- Full Name: Gordon
Yes my mistake, it is .ptzSAttaya wrote: ↑Fri Jun 16, 2017 9:29 pmas of 6.2.4.30, not PTS, maybe you meant PTZ.gordonired wrote: ↑Fri Jun 16, 2017 7:48 pm I have not worked with Pix4D, but if you are trying to import a point cloud, Scene allows the import of .ptx, .pts, .xyz and e57 files. These will import, and you will be able to do registration. I've only used the older version of Scene (5.4), and in this version you need to jump through some hoops before you can register faro scans with external point clouds.
- Full Name: Nikit Shetti
- Company Details: Delta V Forensic Engineering
- Company Position Title: Senior Forensic Animator
Any luck with aligning pix4d point cloud with scan data in scene ? I was succesfully able to import the pix4d point cloud into Scene but had no luck aligning it with the scan data.
- MarkL
- Full Name: Mark Lupton
- Company Details: Wolverton
- Company Position Title: LASER Scanning
- Skype Name: [email protected]
I think you’d be better off picking out some points from the faro scans and applying them as control points in Pix4D. If you then bring the Pix4D las into Scene you could see if c2c tightens it up. I haven’t tried this exactly, but I did compare scan and UAS data in Civil3D by applying faro points to the UAS data in Pix4D.
- Thanh cao
- Full Name: Cao Phuc Thanh
- Company Details: Star Global JSC
- Company Position Title: Applications Engineer
- Country: Viet Nam
Hi
Here, with point cloud data in Pix4D software you can export to .xyz or .las files. If .xyz files you can import directly into SCENE. If .las you can change to .e57 in Recap. After import point cloud (UAV) data into SCENE, you should processing it. Then using Correspondence View to do registration (PC(uav)vsPC(scanner) and finally you use c2c to algining them.
Best regards
Thanh
Best regards
Thanh
