Cyclone- Error 0 - index was outside bounds of the array
Jamiejyoung
Full Name: jamie young
Company Details: Newcastle University
Company Position Title: Undergraduate
Post by Jamiejyoung »
Hi all
I am trying to import a P40 Leica Scanstation project into Cyclone 9.1.4. It is one project containing 3 scans with imagery, the project will start importing into cyclone. However, after the file is 6 - 9 % downloaded, I receive the error
'Failed to import following object(s):
N:\Data\1114CIY
reason: Error: 0 : Index was outside the bounds of the array.'
I have tried to download the data using the 'Download data using the P20 Data Copy Tool', however this is ineffective. I hope someone can hope as I don't want lose a days scanning.
Jamie
LeicaUK_RC
12
Full Name: Phil Marsh
Company Details: Leica Geosystems part of Hexagon
Company Position Title: Reality Capture Director UK
Skype Name: Phil.H.Marsh
Been thanked: 52 times
Re: Cyclone- Error 0 - index was outside bounds of the array
Post by LeicaUK_RC »
It sounds like your importing the data to a shared server. Try the unshared server and it should be OK ;)
Also it might import quicker if you move the data to a local drive.
Leica Geosystems
M: 07540 201383
E: [email protected]
W: www.leica-geosystems.com
Jamiejyoung
Hi Phil
I have tried this morning to import the data under a unshared server and after 8% the same error appears again unfortunately. I did manag to import one scan as a partial import and when viewed in modelspace the file was blank apart from my control points and targets
Jamie
Phil Marsh
16
Skype Name: phil.h.marsh
Has thanked: 119 times
Been thanked: 36 times
Post by Phil Marsh »
Then its an issue with the raw data. Split this off using the data copy tool then import the single scan world.
LASER SCANNING FORUM
pawlo06
6
Full Name: Pawel G
Company Details: Vision
Company Position Title: BIM Coordinator
Post by pawlo06 »
Hi all,
Has anyone managed to solve this issue? I've got exactly the same problem. None of the above tips seem to help...
MTSurveys
Full Name: Mark Townend
Company Details: MT Surveys Ltd
Country: U.K.
Post by MTSurveys »
Hi All,
We had this same error today, but remembered that the scanner froze on one setup and had to do a reboot on the scanner by switching the scanner off and on again
We just did a partial import, making sure not to include the scanworld where it had frozen.
